jps
posted on 1/2/15 at 09:35 AM |
Carpentry advice please!
I thought the collective may have some experience, or know a good site to look for hints and tips for a couple of projects...
I need to kit out my new garage with shelving, workbench, storage, etc. I'm thinking of using 2x4 for the framework as much as possible because
I can get it for nothing, but apart from that the only objective is 'locost'... I'm especially looking for pointers on the best way
to do all the joints...
I also need to build a wall to wall / floor to ceiling bookcase inside, with some cupboards incorporated. Something like this:
http://www.decohubs.com/thumbs/floor-to-ceiling-bookcases.jpg
I've built some similar shelving before from Conti board, but suspect there may be a better material and I don't know how to do
cupboards...
posted on 1/2/15 at 10:21 AM |
Google carpentry hints and tips?
steve m
posted on 1/2/15 at 11:30 AM |
If I was to do my garage again, or move and start again, mine would be decked out with kitchen cabinets
as much as possible,
unless bought on ebay, probably not cheap though
steve
jps
posted on 1/2/15 at 06:53 PM |
Funnily enough I've already tried that. And found it surprisingly unhelpful, hence asking here (doubtless plenty of other LCB'ers have
fitted out their garages?)
posted on 1/2/15 at 07:02 PM |
Just screw the timbers together with big screws, no need for fancy joins. 18mm ply works well for shelves as it's strong and you can sand the
edges. Contiboard will have sharp splinters.
mark chandler
posted on 1/2/15 at 07:56 PM |
Forget contiboard, ply is your friend, once screwed to the wall it will not shift, I would let the horizontals into the uprights by 1/2" and
screw and glue.
Rosco86
posted on 1/2/15 at 10:04 PM |
Ive made a nice workbench out of 63mm x 38mm studding, glued loads of it together to make the top, you could do the same for your book shelf if you
can get it for free, i will get you a picture tomorrow if your interested
talkingcars
posted on 1/2/15 at 10:09 PM |
https://scontent-a-lhr.xx.fbcdn.net/hphotos-ash2/v/t1.0-9/533648_689094621107808_1739475290_n.jpg?oh=b99544e13e9ef7682028d56694d9ef18&oe=55229036<
br />
This is what I did for shed with free floor boards and 2x4.
[Edited on 1/2/15 by talkingcars]
bi22le
posted on 1/2/15 at 10:39 PM |
When i move i am going to use an old kitchen suite. I was gutted a few weeks back because a sharp looking load of high gloss coloured kitchen units
went on ebay including a dishwasher (read greasy bits cleaner) and sink ( always good for a garage) for just over 100.
Absolute bargin.
Please read my ring story:
samjc
posted on 2/2/15 at 12:01 AM |
Got cheap metal brackets holding up scaffolding boards for shelfs, a bench made of 2x4 which i later added cheap airing cuboard door cut in half to
make doors. Also used left over kitchen worktop for my othe counter/workbench in the prosses of extending and reroofing the garage but will be adding
loads of waste high shelfing units using 2x2 and left over loft boards.
FASTdan
posted on 2/2/15 at 07:35 AM |
As said simply use 4" screws to do the joints, no need for anything more complicated - but pre-drill the first member to ensure the joint pulls
tight. Myself and my dad (a joiner by trade) have done many work benches/racks etc in our various garages and workshops over the years. 18mm ply for
the shelves will be solid as a rock.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Fred W B
posted on 2/2/15 at 04:18 PM |
Pictures of some of my shelves.
dhutch
posted on 2/2/15 at 07:55 PM |
I must say this is my method. Dad made a cracking wood bench for himself, 3*3 up rights and 2*3 cross members, lap joined together by an inch, tight
fitting joints (you could carry the frames around without the bolts) and then bolted up with coach bolts. Its a work of art, but while if I had a
table router I might set up and make them, in all reality life is too short and you can do a lot very fast with good quality large woodscrews.
I would then also glue each join with Polythene woodglue*, at least the ones the make the frames. Secure together, 5mm ply for the back, 10/12 for the
shelves of the bench depending on loading and framing used.
Contiboard and other chipboards are fairly crap, but for low-load wipe clean shelving you can do a lot worse then melamine faced chipboard.
*Various brands available, gator glue, gorilla glue two well marketed version. Single pot, fairly fast curing. Shelf life once opened is a few months
but dont by more than you need to 'have it in' and expect it to last years.
Everbuild Gator Glue Wood Polyurethane Adhesive - 250ml
Daniel
[Edited on 2/2/2015 by dhutch]
