New Topic New Reply
Author: Subject: Pinto to Zetec conversion cost
sonic
posted on 14/6/16 at 08:34 PM Reply With Quote
As title really
Toying with the idea as a winter project of converting my Pinto engine Indy to a 2Ltr Zetec
What would I need and cost ?
Bonnet
Engine mount
Exhaust manifold
Wiring I would have to get somebody else to do as electrics are not my strong point, cost?
Engine, new ones seam reasonable cost wise
What else ?
big_wasa
posted on 14/6/16 at 08:41 PM Reply With Quote
Budget depends on expected power and your ability to make stuff.
Cost from very little to thousands.
madteg
posted on 14/6/16 at 08:43 PM Reply With Quote
Go for a black top its a better engine than silver top
sonic
posted on 14/6/16 at 08:56 PM Reply With Quote
Thinking of keeping it standard to start with and upgrading over time, std they are about 135 bhp I think
chris
posted on 14/6/16 at 09:07 PM Reply With Quote
got a zetec blacktop 2ltr with engine mounts and 1.8 flywheel that may be for sale
it was running bike carbs with megajolt ECU and was rolling roaded and produced 150bhp
got a few other bits that may also be for sale
[Edited on 14/6/16 by chris]
chris
posted on 14/6/16 at 09:16 PM Reply With Quote
as for the parts needed to start from scratch
engine mounts
exhaust manifold
induction manifold and carbs or TB
ECU
fuel pump
flywheel 1.8 OR 2LTR
starter motor
alternator
and zetec engine
shortened sump
joneh
posted on 15/6/16 at 11:43 AM Reply With Quote
body work may be required as the exhaust will be swapping sides...
hughpinder
posted on 15/6/16 at 11:55 AM Reply With Quote
You don't need an ecu/throttle bodies unless you want to get big power -search for big_wasa for information on using the standard ecu. Alternator depend on what will fit - you may be able to use standard if you can make brackets.
regards
Hugh
Dick Axtell
posted on 15/6/16 at 12:10 PM Reply With Quote
Having changed from Xflow to silvertop Zetec, I have no doubt whatsoever that it'll cost you more than your initial budget!!
[Edited on 15/6/16 by Dick Axtell]
New Topic New Reply
