New Topic New Reply
Author: Subject: Brake pedal bracket
paulbeyer
posted on 7/11/02 at 11:12 PM Reply With Quote
Brake pedal bracket
What brake pedal bracketry is everyone using to connect into the mastercylinder?
The setup for the sierra doesn't fit. It looks like you need some sort of U bracket and clevis pin arrangement to fit to the pedals supplied by MK.
Bob has suggested I take a look at Merlin Motor Sport, any other suggestions?
CairB
posted on 8/11/02 at 12:50 PM Reply With Quote
I used a brake actuating rod and clevis pin from Merlin on my Indy with MK pedals. I had to cut the end off the rod and dome the shaft to suit the Sierra piston. From memory, I think Merlin said it was for a Girling master cylinder. It also needs an M8 fine nut, clevis pin and R clip.
If your mounting the cylinder direct to the bulk head the you should consider stiffening the cylinder mount. I did mine by fitting 25mmx3mm ally angle behind the cylinder, from bottom to near top of bulkhead, others have fitted plates but unless you get it to come a long way up it will be more work, more weight or less stiff.
Hope this helps,
Colin
speedthing
posted on 12/11/02 at 09:52 PM Reply With Quote
the u bracket from the back of a brake
pedal as fitted to mk3 mk4 vauxhall
cavalier take the thin nut as well
then get a long shank bolt cut of the
head square that what i did and it works
New Topic New Reply
