Dusty
posted on 4/11/05 at 07:02 PM |
Randon restarts.
My computer running XP, 1.8 cpu, 512m of ram has just started shutting down and restarting itself randomly. Any obvious places to look first? Software
or hardware? Any ideas would be very helpful. TIA.
Danozeman
posted on 4/11/05 at 07:06 PM |
Have u got any virus progs or spyware progs?
Dan
Messenjah
posted on 4/11/05 at 07:09 PM |
when the cpu has too much to think about and cant handle mor estuff it will start to heat up and if it gets to hot it will shut itself down
if you have alot fo things open at a tme it may be worth getting more ram ....
also it could be a virus i had one that did that try and run spyware search and destroy and also search for documents or files created at the same
time that it started happening
also the simplest thign could well be the answer and it could be that stupid stickykeys thing happened to me the other day and it restarted
everytime i pressed some letter ont he keyboard cant remember whcih one it wa sbecause the shift or ctrl key was held down cant remember which
in the start bar by the clock is there a bunch of squares and rectangles one of them filled in in black tharts stickykeys hold ctrl and shift for a
little while and it will switch off make sure you hold them each time the coputer stars up and it will switch it off
viatron
posted on 4/11/05 at 07:13 PM |
Classic sign of overheating, other than that my money would be on a dodgy driver. Has your BIOS got a health check sub menu? if so check it next time
it reboots and check out the temp. A good utility for monitoring CPU temps is "Motherboard Monitor"
http://mbm.livewiredev.com/
Mac
Messenjah
posted on 4/11/05 at 07:26 PM |
overheating was also my first guess as in above post
more ram and more fans in the case
www.aria.co.uk
Winston Todge
posted on 4/11/05 at 07:31 PM |
Ditto on the overheating thing...
Loose CPU heatsink and also northbridge heatsink can cause random restarts also...
But that's from an overclockers point of view...
^^ Ditto the other things above though ^^
Open case and put big fan pointing towards it to rule out overheating. Then look at other stuff...
Chris.
Metal Hippy
posted on 4/11/05 at 07:44 PM |
From past experience I'd say faulty memory.
For the computer to randomly restart and not just under load I'd say it's not overheating..
If it was that it'd just shut down and do naff all, but for it to restart...
Memory.
Cock off or cock on. You choose.
posted on 4/11/05 at 08:01 PM |
i had a worm cause that trouble in the past.
DorsetStrider
posted on 4/11/05 at 08:04 PM |
Just to get told that I don't know what I'm talking about....
These were the exact same symptoms that my PC presented shortly before the power supply blew itself up.....and set fire to the carpet! My advice get
yourself a standby PSU.
Who the f**K tightened this up!
mookaloid
posted on 4/11/05 at 09:19 PM |
See this thread
http://locostbuilders.co.uk/viewthread.php?tid=31091
We reseated all the cards and memory and vacuumed all the dust and fluff out.
Problem gone away
Mark
Tim 45
posted on 5/11/05 at 01:23 PM |
I had a problem like this.
Turned out the CPU had fried becasue one of the fans had failed
It was an Athlon K7 i think.
I would have thought checking for overheating as suggested above would be the best place to start.
HTH
