New Topic New Reply
Author: Subject: Clutch Cable Problem
Marshy7771
posted on 7/11/05 at 11:57 AM Reply With Quote
All,
My clutch cable has snapped twice in the last 6 month, each time a brand new cable was used. It is snapping at the point it attaches to the clutch pedal.
Can anyone please offer any advice as its such a pig to fix each time.
Thanks,
Dave
mac1ZR
posted on 7/11/05 at 12:14 PM Reply With Quote
Hi, we had the same problem initially. Make sure the pedal is pulling the cable cleanly in a straight plane, and not pivoting around where its attatched to the pedal.
NS Dev
posted on 7/11/05 at 12:28 PM Reply With Quote
yep, as above, make sure that the cable is free to rotate at the clutch pedal end. If not they wil snap very quickly.
throttle cables do exactly the same.
Marshy7771
posted on 7/11/05 at 12:36 PM Reply With Quote
Thanks guys
Where is th ebest place to source a new cable from and what the best way to attach the cable to the pedal
mac1ZR
posted on 7/11/05 at 12:47 PM Reply With Quote
cable from mac#1.use a bolt and nyloc nut to attatch the cable to the pedal,not doing the nut up too tight so the cable is free to move. Rescued attachment PB070093.JPG
DarrenW
posted on 7/11/05 at 01:01 PM Reply With Quote
Just to add to Mac1ZR's explanation. The pedal end connection looks like a banjo fitting. The bolt thro its centre (left slack) allows the cable to keep a straight path through the chassis hole when the pedal is pressed.
IIRC mac#1 supplied the banjo type fitting seperately. The clutch cable std end being replaced with it (secured with 2 grub screws).
lsdweb
posted on 7/11/05 at 01:11 PM Reply With Quote
Or you could use a pull rod clutch
MikeR
posted on 7/11/05 at 01:55 PM Reply With Quote
except you have to have the engine and gearbox solidly mounted to do that!
lsdweb
posted on 8/11/05 at 09:50 PM Reply With Quote
Mine is solid mounted but I guess the pivot could be mounted to the engine / bell housing which should allow for some movement.
New Topic New Reply
