Author: Subject: Tiger Tank.......
DaveFJ
posted on 17/12/05 at 10:15 AM Reply With Quote
Tiger Tank.......
I am about to have an Ally fuel tank made for my Avon. Obviously I have the dimensions in the book but thought it worth checking with you fine gentlemen.....
SO my question to all Avon builders is this > what are the optimum dimensions etc for the Avon tank ?
I also fancy putting the fuel cap on the horizontal flat surface beside the 'boot box' as I have seen others do, will the filler tube need to be moved ?
Dave
Metal Hippy
posted on 17/12/05 at 11:59 AM Reply With Quote
Tiger tank...?
Cock off or cock on. You choose.
posted on 17/12/05 at 06:07 PM Reply With Quote
Oh a Porsche from his WW2 period.
"Kelly ! ya like my new beautiful tank ? ah bought it from the krauts"
"a terrible tank the fuel system leaks"
"Like ah told you stop making with those negative waves"
("Kelly's Heroes"
DaveFJ
posted on 19/12/05 at 05:06 PM Reply With Quote
No-one got any input ?
Come on lads - usually everyone has their say about Tiger products and dimensions....
Dave
Viper
posted on 19/12/05 at 05:26 PM Reply With Quote
the only thing i know about Tigers dimensions is they use an elasticated tape measure and rubber rulers
Avoneer
posted on 19/12/05 at 05:44 PM Reply With Quote
What, they've actually now bought a measuring device???
Must be xmas.
Pat
shades
posted on 19/12/05 at 06:07 PM Reply With Quote
I have fitted the R6 (i think) tank to mine. Using fuel injection so needed a fill return. Also aim to put the filler on the horizontal. So far so good it looks like it will be OK. Its also got L shaped bits welded to the sides for fitting, which meant no tank straps.
Can get measurements, take pic if you want? Also have a new steel tiger tank for sale if needed?
DaveFJ
posted on 19/12/05 at 07:50 PM Reply With Quote
Pics and dims would be good as I am having a ally tank fabricated for less than half Tigers prices...
I also am going fuel injected so will need return pipe....
Dave
studon
posted on 20/12/05 at 07:55 PM Reply With Quote
ali fuel tank
I have got a Tiger Ali fuel tank it is from a B6.
The dimensions are pretty much the same as the std tank(which I have currently fitted to my Avon.
I also have my fuel filler on the horizontal flat on the near side.
I did not need to modify the tank to suit this.
I can perhaps get you some measurements if you want.
I cannot say I have had any issues with the measurements of the both the steel or ali tank.
ta Stu
deneo
posted on 22/12/05 at 07:29 PM Reply With Quote
ali tanks
if u want a ali tank 2 fit a avon just send me the sizes and i will make one for about £50 + £10 post get my avon on 28th jan thanks.
DaveFJ
posted on 23/12/05 at 08:37 AM Reply With Quote
My order will be wending it's way to you in the near future dene.....
cheers
Dave
Lightning
posted on 23/12/05 at 12:57 PM Reply With Quote
mines ally with baffles. Can't remember dims. I just measured the distances between the chassiss members. I'll be crawling under sometime over the hols to dick about with the wishbones so I'll measure then. BUr who knows whether yours is the same size. Tiger won't.
Schrodinger
posted on 3/1/06 at 02:13 PM Reply With Quote
Dave you have U2U
Keith
Suffolk
