New Topic New Reply
Author: Subject: Progress
Hammerhead
posted on 25/5/07 at 02:30 PM Reply With Quote
Progress
Not much, but feels like a big leap forward for me.
Chassis lifted over engine so I can design and fabricate my engine mounts.
Hammerhead
Hammerhead
posted on 25/5/07 at 02:31 PM Reply With Quote
and another (don't know how to multiple post pics) Rescued attachment DSC02231 copy.jpg
stevec
posted on 25/5/07 at 02:34 PM Reply With Quote
Well done Steve.
Please put plenty of pics up so I can see how you position it.
Steve.
Hammerhead
posted on 25/5/07 at 03:06 PM Reply With Quote
will do steve, I will have to update my website to include the backlog of pics I have gathered.
I think positioning will be tight, the oil filter is quite close to the bottom chassis rail. I might drop the engine a little lower in the chassis as at the moment it is about 1/2" below the bottom chassis rail, I think 1" below would be ok.
I am buying a V6 type 9 rather than mess around with the standard one I have. Apparently the V6 has slightly better ratios.........we will see.
stevec
posted on 25/5/07 at 03:20 PM Reply With Quote
Steve I did a few guesstimates on position and 1 to 1 and a half inches is about what I came up with, How far forward are you going,? I was thinking of the front of the belt cover being just under the nose cone, although further back would perhaps be better.
Good luck with finding a V6 box. I will keep an eye open.
Steve.
Hammerhead
posted on 25/5/07 at 03:59 PM Reply With Quote
Steve.
I will have to take those datum points from the chassis rails as I am attempting my own design bodywork (like an idiot) so it wont actually look like an indy at all.
I have the shortened sump from caterham and would like to get over speed humps without drama, so I should think 1" below would be ok, but I took the height of the sump from the ground from my wifes merc C class and that is about 12cm which would make me sump 1/2" below the chassis.
I'm sure that 1" will be fine for me though, but I would like to get the engine as low as possble so I can design my engine cover to be low.
Edited to add: Woohoo!! just won my recon gearbox off ebay £51 for a V6 type 9 from a Capri. Hopefully pick it up tomorrow and see where it all fits together in the chassis.
[Edited on 25/5/07 by Hammerhead]
snoopy
posted on 25/5/07 at 10:42 PM Reply With Quote
cam cover needs to be under indy bonnet buldge but right at the front of the buldge if using indy bodywork and its a tight fit
New Topic New Reply
