New Topic New Reply
Author: Subject: Nose Cone
Stuart_B
posted on 3/2/08 at 06:00 PM Reply With Quote
Nose Cone
hi, i am starting to fit the body work and i do not know how the nose cone fit??
Advice and picture need please
thanks
Stuart
Guinness
posted on 3/2/08 at 06:10 PM Reply With Quote
I used a pair of hinges on the underside of the bottom chassis rail, fixed into the bottom return on the back of the nose.
Hinge Indy Nose
Hinge Indy Nose
Then a couple of cuts in the sides for the headlamp bar
HTH
Mike
Simon
posted on 3/2/08 at 06:11 PM Reply With Quote
Stuart,
Nosecone should be self explanatory. You'll have horizontal faces that run on top of the side rail of the chassis, and nearly vertical faces that butt up again the pieces of chassis connecting the top and bottom rails.
Simon
Stuart_B
posted on 12/2/08 at 06:42 PM Reply With Quote
what sort of hinges did you use to make teh nose cone higened?
thanks
Stuart
Guinness
posted on 24/3/08 at 06:38 PM Reply With Quote
http://www.screwfix.com/prods/63852/Ironmongery/Hinges/Flush-Hinges/S500-Flush-Hinge-60mm
Sorry for the delay in responding Stu!
HTH
Mike
Stuart_B
posted on 24/3/08 at 07:28 PM Reply With Quote
The nose cone is fitted now, and it hinges.
New Topic New Reply
