New Topic New Reply
Author: Subject: First real drive pre SVA
badding
posted on 17/2/08 at 01:18 PM Reply With Quote
Yesterday I had my first testdrive...It was 3 degrees, but still had a lot af fun
Only a few points that need to be taken care of..
Mudgarts for the front wheels, little stones where flying all over the place
Self centering was awfull,how can you fix this, I read about the springs, but what is the correct way for self centering?..
The trottlecable isn't pull back fast enought when the gaspedal is released..
Clutch was slipping after a couple of laps, what clutchplates springs is best for a zx9r and what oil is best, now I use fully synthetic oil...
On the positive site...the brakes were working very well, all bits stayed on the car , speedo was correct 30mph was 26 mph on the tom tom.All the lights work..so very please with the result so far.I must say for 142bhp it is very fast, althought before the clutch started slipping Rescued attachment CIMG2233.JPG
nitram38
posted on 17/2/08 at 01:21 PM Reply With Quote
Do a search for self centering, it has been discussed before...........exhaustively !!!
You need more castor which means remaking your top wishbones.................thats if you want to live!
As to your clutch, are you supposed to use fully synthetic oil?
I don't know what the mods are for this clutch
Extra spring for the throttle cable and perhaps one on the pedal too?
[Edited on 17/2/2008 by nitram38]
gingerprince
posted on 18/2/08 at 09:49 AM Reply With Quote
For my throttle cable I have a spring on the other side of the throttle cam. So bowden cable outer and inner from pedal to throttle cam, then from the other side of the cam (where other half of push-pull would be on the bike) there's just a cable inner with spring on it.
You can see the spring on the bottom of this picture sticking out between carb 2 and 3. Fastened at each end under tension with allan-key doofers (ignore the other bits it's a recycled picture ): -
Flappy Hoses
Flappy Hoses
Otherwise you can put a spring on the pedal itself.
[Edited on 18/2/08 by gingerprince]
lotusmadandy
posted on 20/2/08 at 08:56 PM Reply With Quote
I called mk about the self centering and was told to set the tracking to toe out a couple of degrees for the test.
my indy passed sva no problem.i was told that as the rack is narrowed self centering is almost non existent.
had no problems with my steering though....
chunkytfg
posted on 21/2/08 at 01:03 PM Reply With Quote
I would very much doubt you are supposed to use fully synth in a ZX9R engine.
I would recommend semi synth.
Fully synth does have a reputaion amoungst the bike community of making clutches slip when put in an engine not designed for it and as such the extra effort of trying to pull the car might be just too much.
Also check you have enough slack in the clutch cable. even if it is just taught it may pull enough to start slipping.
badding
posted on 1/3/08 at 08:02 PM Reply With Quote
nearly fixed...
Ok took the clutch apart, new kevlar plates and 30% stronger springs are on the way.. Rescued attachment CIMG2244.JPG
badding
posted on 1/3/08 at 08:04 PM Reply With Quote
badding
posted on 1/3/08 at 08:08 PM Reply With Quote
Loosened the nuth on the steering colum, now the steering goes al lot easier which will help the self centering... Rescued attachment CIMG2248.JPG
jacko
posted on 1/3/08 at 10:08 PM Reply With Quote
HI when i had my SVA i had the steering 2-3dgs toe out + tyres at 30 pounds
my car has been on the road for 4years and i am still alive
and i drive hard
Jacko
Bluemoon
posted on 3/3/08 at 10:44 AM Reply With Quote
Not sure you should loosen that part of the steering rack. from memory it's apart of the pre-load on the rack...
Dan
ragindave
posted on 4/3/08 at 12:49 AM Reply With Quote
slippng clutch
Have you been using motorcycle oil or car oil in your car?
New Topic New Reply
