Can anyone tell me what offset I need for the tiger Avon please, I'm looking for 7x15 but not sure what offset or how to work it out, cheers
7" will be to wide and you'll start getting rub issues, tiger recomend 6.5j x 15 et39(ish). your wheels will be roughly 1" wider than stated as the 7" is measured between the inner part of the wheel.
U2u sent
I've got 7" on mine I did have to trim 5mm off the osr wheel arch though. You want around et35 to et 38 offset.
Thanks Neil, do I need any certain markings on them for iva?
No marking on wheels for iva that I know of. Got mine through with second hand R888 on as well
do u know if I can fit 13 inch wheels?
