Zetec Oil Filter Part No.
ttalps2000 - 25/10/17 at 07:27 AM
Does anyone know the oil filter number for a zetec 1800 silver top? It is the filter that is attached to the oil pump and comes out by the crank.
Forgot to get the numbers off it last night!
jossey - 25/10/17 at 08:45 AM
The tall one or short?
[Edited on 25/10/17 by jossey]
jossey - 25/10/17 at 08:54 AM
Tall is l10169ps
Part number 501590018
Short one Is l10174ps
Part number 501590068
Got mine from euro car parts for about £4
Hope that helps
Both are Crosland part numbers.
ttalps2000 - 25/10/17 at 08:55 AM
It has a long one on there at the moment, but tempted with a short version to give me a little more space!
matt5964 - 25/10/17 at 09:31 AM
Short one mahle oc606 is what I use only £2.00 from our local motorfactors
jossey - 25/10/17 at 09:47 AM
I've used short for ages now
kingster996 - 25/10/17 at 09:53 AM
Westfield supply engines with a WIX WL7064.  The WIX box states the
following equivalents:
MANN W9101
KNECHT OC11
FRAM PH2874
PURFLUX LS506
FIAAM FT4763
FILTRON OP518
taller one:
FRAM PH966B
Crosland 573
Mann W712
Six WL7098
big_wasa - 25/10/17 at 11:04 AM
I use these as well.
DJT - 27/10/17 at 11:01 AM
Short one: Mann W77. Has the correct imperial, not metric, thread. Think it might cross reference to other models posted here.
SteveRST - 2/2/18 at 02:25 PM
If you need a REALLY short filter (as I did) then the Mann W85 is 49mm high (10mm shorter than the Mann W77) BUT it does not have the Zetec 3/4 UNF thread, but an M20 thread so you'd need a 3/4 > M20 converter spigot like this: https://www.speedflowshop.co.uk/m20-to-34-unf-oil-filter-fixing-spigot-570-m20-34-3450-p.asp
I had to use it as couldn't find filter that short in 3/4 (though I'm sure there is one out there).
