Author: Subject: Ackerman problem?
dream
posted on 12/1/13 at 03:19 PM Reply With Quote
Ackerman problem?
Does the avon really have problems with the steering rack placement?cheers
snakebelly
posted on 12/1/13 at 03:52 PM Reply With Quote
Are you referring to bump steer, depending on your setup it can be an issue but until the front end is built up and all settled it may be difficult to define, things like ride height and wheel size can contribute . Rob has just had a nifty mod done by Mac#1 to get rid of his, I'm sure he will be along shortly with pics
Hth
snapper
posted on 12/1/13 at 04:11 PM Reply With Quote
Ackerman is a line drawn from the track rod end through the hub pivot point to the center of the rear axle
Bump steer is a different issue
I eat to survive
I drink to forget
I breath to wee my ex wife off (and now my ex partner)
snakebelly
posted on 12/1/13 at 04:36 PM Reply With Quote
Yes but as far as I'm aware the Avon doesn't have an Ackerman issue but can have a bump steer issue, hence me asking for clarification
dream
posted on 12/1/13 at 05:28 PM Reply With Quote
i mean the inner wheel in a corner goes through a tighter circle,
posted on 12/1/13 at 05:40 PM Reply With Quote
That would indeed be ackerman rather than bump steer then. Since you are using hubs off a donor, all you can change is the position fore/aft of the steering rack. Have a read up (via google) about ackerman and rack position, and compare to where yours will be.
posted on 12/1/13 at 07:04 PM Reply With Quote
Any picture I have seen of Avon front geometry show it has toe-in in turns.
Basically set the front wheels in the straight ahead position and looking down from above imagine a line joining the centres of the track end ball joints.
If the steering rack lies behind this line you have at least partial toe out in turns -- which in effect gives you some ackerman.
If the steering rack lies ahead of the imaginary line your car has toe-in in turns -- which is not good as it gives poor turn in and front end grip.
[I] What use our work, Bennet, if we cannot care for those we love? .
jossey
posted on 12/1/13 at 07:38 PM Reply With Quote
As mac has said from my research n calculations its just bump steer but this can be solved with rose jointed rack ends. See laptoprobs pics.
I shouldnt have the issues due to my bike engine setup being lighter on the front but we will see. I have the wider wishbones as the ther real issue with the aim is the under steer due to the narrow front end.
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
laptoprob
posted on 13/1/13 at 08:43 AM Reply With Quote
Rudy
posted on 9/2/13 at 08:52 AM Reply With Quote
please read this http://www.locostbuilders.co.uk/viewthread.php?tid=116631
Sorry about my English
