xico_ze54
posted on 22/1/13 at 04:08 PM |
brake tandem cylinder in locosts?
hi
did anyone already aplied with success a tandem master cylinder in a locost? this because I saw in every project the typical two-cylinder with balance
bar.
can anyone explain me why this "recipe"?
thank you.
Amadeu
http://www.viseudesign.com/Sevenesque-36.htm
rallyingden
posted on 22/1/13 at 04:17 PM |
My build used Tandem master cylinder.............. No probs
IVA passed fine.
RD ![](/images//smilies/smile.gif)
posted on 22/1/13 at 04:56 PM |
For reasonable pedal pressures without a servo you need a smaller bore tandem cylinder than the original Ford a lot of people have used the Fiat
124 cylinder.
DavidM
posted on 22/1/13 at 07:10 PM |
My car passed SVA with mk2 Escort non servo tandem cylinder. I had no problems with pedal pressure. The pedal box and pedal were made to give the same
leverage ratio as the Escort doner car.
[img]http:// [/img]
Proportion is Everything
russbost
posted on 22/1/13 at 08:14 PM |
I use the standard Toyota MR2 Mk1 cylinder on the Furore, just remove the servo, can lock the front brakes up with little effort.
xico_ze54
posted on 22/1/13 at 09:34 PM |
so, and what's the cylinder bore you both used in your cars?
cheers
