Author: Subject: Air temperature sensor
wombat
posted on 17/4/14 at 01:50 PM Reply With Quote
Where is the best place to mount the Air Temp Sensor i have with my MS2 loom please?
posted on 17/4/14 at 03:13 PM Reply With Quote
In the air box, or if your running a pipercross or similar in the back plate.
No filter? Just fasten it close to the inlet trumpets.
posted on 17/4/14 at 04:18 PM Reply With Quote
If you look at any production setup you will see they measure the IAT close to where the air enters the cylinder head either in a branch of the manifold or in the plenum close to where it joins a branch.
The IAT is usually a lot higher than than ambient air temperature.
