Author: Subject: BEC clutch change
olimarler
posted on 19/5/14 at 03:23 PM Reply With Quote
BEC clutch change
Hi all!
I'm about to change my clutch on my honda CBR
I have Barnett springs and honda clutch to go in.
I'm gonna soak friction plates over night in the oil.
But is there any advice that I need to do before I start the job tomorrow evening.
Any special tools? Any torque setting on the springs etc
I have the Haynes manual but I'd like to hear your experience
Thanks in advance
Oli
minitici
posted on 19/5/14 at 04:12 PM Reply With Quote
Don't soak the plates in synthetic oil.
Use a standard mineral bike oil.
olimarler
posted on 19/5/14 at 04:24 PM Reply With Quote
Check!
I have the lol I use in the bike a castrol oil that's good to go!
mark chandler
posted on 19/5/14 at 04:25 PM Reply With Quote
Do not over tighten the spring retainers, easy to strip the threads then the basket is toast.
olimarler
posted on 19/5/14 at 04:34 PM Reply With Quote
That's makes me nervous! If anyone would do that it would be me!!!
mark chandler
posted on 19/5/14 at 04:44 PM Reply With Quote
Just use a 1/4" wrench and hold the head, not the arm, you can feel when the spring plate has touched the basket then just a little nip.
The book probably have a torque in inches per pound, not foot per pound, a massive difference!
And work around evenly when you remove and install, one turn per head then the next one.
[Edited on 19/5/14 by mark chandler]
olimarler
posted on 19/5/14 at 04:48 PM Reply With Quote
Can't see the torque setting :-( never good!!
pewe
posted on 19/5/14 at 05:05 PM Reply With Quote
IIRC 9ft-lb.
Best to check on CBR forum though.
Cheers, Pewe10
Proby
posted on 19/5/14 at 06:12 PM Reply With Quote
Its a very straightforward job, take your time and you'll have no problems.
Visit GraphicMonster
olimarler
posted on 19/5/14 at 10:11 PM Reply With Quote
Ok so all good friction plates are soaking need to get bit more oil to completely cover but all good!
But the plates do I need to soak them?
Also comparing to old both original honda they look different do I need to be concerned?
Cheers guys
Oli
olimarler
posted on 20/5/14 at 09:01 PM Reply With Quote
Guys,
Thank for your help it's all done and worked a dreams!,
Very proud of myself
Oli
Proby
posted on 21/5/14 at 08:24 AM Reply With Quote
Well done Oli.
