Author: Subject: Wheel nut torque
JacksAvon
posted on 23/8/14 at 07:07 PM Reply With Quote
Wheel nut torque
Having lost my book of notes, can anyone tell me the wheel nut torque for an Avon
Sierra rears Cortina fronts please.
posted on 23/8/14 at 07:10 PM Reply With Quote
Pot luck really, local tyre place here does them up to 110nm regardless of model by the looks of it.
Personally I'd go a bit higher, maybe 150? Totally up to you but Google not come up with anything?
ian locostzx9rc2
posted on 23/8/14 at 07:26 PM Reply With Quote
90 to 110 nm max
posted on 23/8/14 at 07:49 PM Reply With Quote
For me, it's an 18" bar with a 90kg dude gently bouncing on it. Ie nowhere near loose but equally not as tight as you could.
Hope that helps!
bi22le
posted on 23/8/14 at 11:35 PM Reply With Quote
I do mine up as tight as I can with a box wench by hand. I still need to stand on them to get them undone.
Please read my ring story:
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 24/8/14 at 07:51 AM Reply With Quote
I do the wheel nuts up to 40ft.lb on my single seater. 3/8" unf.....
b3ngy
posted on 24/8/14 at 08:11 AM Reply With Quote
80-90lbft is a good ballpark.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 24/8/14 at 08:26 AM Reply With Quote
Ford wheel nuts, 50/56lbs/ft.............
designer
posted on 24/8/14 at 08:45 AM Reply With Quote
40 to 50lbs/ft is enough
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 24/8/14 at 08:53 AM Reply With Quote
Exactly, see my post above. I run my hill climb car wheel nuts at 40 lbs/ft.
JacksAvon
posted on 24/8/14 at 10:34 AM Reply With Quote
Thanks chaps
posted on 24/8/14 at 02:50 PM Reply With Quote
Ford M12 wheel studs are very easy to shear off, they usually fail under torsion when undoing them. Don't over tighten no more than 60ftlb or 80nm
The old Ford 7/16" UNF were much less easy to shear but the same torque applies.
M14 as used by Honda, BMW, Rover, Mercedes and others need to be a lot tighter to give me he bolt suffcient elastic stretch or they slacken off 120nm.
BL Mini MG Midget used 3/8" studs 50lbs 70nm is enough.
[Edited on 24/8/14 by britishtrident]
