Author: Subject: ST170 Fuel Rail Options?
wombat
posted on 8/12/14 at 09:54 PM Reply With Quote
Was going to use the standard ST fuel rail with the pressure thingy blocked off and an 8mm tail fitted to give a return, but now wondering if I should get a custom rail made?
Thoughts anyone?
mark chandler
posted on 8/12/14 at 10:17 PM Reply With Quote
Why not just use the rail as designed and take the return back to the tank?
[Edited on 8/12/14 by mark chandler]
big_wasa
posted on 9/12/14 at 11:15 AM Reply With Quote
The st170 has no return or pressure regulator it has a damper. You could adapt the port for the pressure switch or I would see if a Black top rail will fit.
kingster996
posted on 9/12/14 at 11:23 AM Reply With Quote
My Silvertop has a modified ST fuel rail - can take a pic if you want?
I used to be indecisive, but now I'm not so sure
wombat
Damper !!! Thats the word I was looking for last night :-)
Following what someone else had done, I was going to blank off the damper, remove the sensor from the end of the rail and tap an 8mm fitting in the end.
Was thinking that a custom rail would probably have less risk of air leaks with a straight in/return.
Are you saying a blacktop rail is effectively just that?
wombat
posted on 9/12/14 at 11:28 AM Reply With Quote
kingster - picture always helpful :-)
DW100
posted on 9/12/14 at 12:26 PM Reply With Quote
Something that would be really useful for people doing things like this is that some cars have a rear mounted fuel filter with built in regulator, flow and return to tank pipes, and a single regulated pressure line going to the front or the car and fuel rail.
I'll try and look up a part no.
Edit to say research shows the filter / regulator I was looking at operates at 6.4 Bar. Lower pressures are achieved by PWM of fuel pump using feedback from fuel pressure sensor.
[Edited on 9/12/14 by DW100]
kingster996
posted on 9/12/14 at 12:36 PM Reply With Quote
This should show you the differences - std ST170 and modded one (with yellow hoses)
[Edited on 9/12/14 by kingster996]
big_wasa
posted on 9/12/14 at 02:12 PM Reply With Quote
Yep that puts into pictures what I mean by using the pressure sensor port for the return but what are you using to regulate the pressure ?
posted on 9/12/14 at 02:34 PM Reply With Quote
Like Kingster there I took the pressure sensor off, drilled right through and put a barbed fitting on blanking the outside off with a plate, all just to tidy it up and point the return back to meet up with the pcv.
kingster996
posted on 9/12/14 at 04:04 PM Reply With Quote
Originally posted by big_wasa
...but what are you using to regulate the pressure ?
You can just see the pressure reg to the left of the modded fuel rail.
DW100
posted on 9/12/14 at 05:01 PM Reply With Quote
This filter/Regulator for a E46 BMW could be useful if a little long.
BMW 3 SERIES E46 320 325 330 316 318 MAHLE ORIGINAL FUEL FILTER PRESSURE KL149
Regulated to 3.5 Bar (3.0 With Vacuum)
wombat
posted on 9/12/14 at 06:25 PM Reply With Quote
🍻 great stuff thanks, will stick with my plan then.
Thanks again.
