Author: Subject: rear lights help
chesney321
posted on 27/12/14 at 01:07 PM Reply With Quote
rear lights help
I have 2 sets of lights for rear of car but really don't want to fit either 1 set is small land rover /mini types and the other is 90mm wipac units problem I have with these is that because they use bulbs you have to cut into arch and the wires and rear or lights are very close to the tyres.i have been looking at the rectangle led ones from car builder solutions what is the general thought of these it says they come with an led flasher unit does that mean that I remove unit I have installed already and will I have to change my front indicators for led ones all help appreciated
CosKev3
posted on 27/12/14 at 01:24 PM Reply With Quote
You can get housings for the Wipacs,either double ones or angled single ones,playscool sell these the cheapest.
Have a look at zx12dug's latest pics for pics of the rectangle led rear ones fitted.
chesney321
posted on 27/12/14 at 02:35 PM Reply With Quote
ive had a look at zx12 dugs light and they are what I think I will go for just need to know where from
907
posted on 27/12/14 at 03:20 PM Reply With Quote
I have the CBS led lights but they were only £27 when I bought them.
I had a quick look on the bay and found what look the same for £18.
I have the Wipac bulb lights at the front so a bit of a mix.
Jon Ison recommended a flasher that works with this mix for £7. Search for thread " Wrong flasher unit ? possibly ? " by 907
HTH
Paul G
Pics of lights on the car:-
CosKev3
posted on 27/12/14 at 04:11 PM Reply With Quote
Dug's are off bolt on bits, advertise through E-Bay, but ring them for cheaper deals direct.
Ref flashers, I've bought an adjustable one off E-Bay for only a few £ which you can set up to work with any bulb combination, even works with just my test light connected!
chesney321
posted on 27/12/14 at 04:30 PM Reply With Quote
thank you CosKev3
snowy2
posted on 28/12/14 at 09:14 AM Reply With Quote
these are what i am looking to fit to my next project car (in bits just now and as soon as i finish my present cars repairs..... ;-( )
LED BLACK/RED MOTORBIKE TAIL/BRAKE/INDICATOR/NUMBER PLATE REAR LIGHT MOTORCYCLE
I want a minimal look to the rear of my car next time.
sometimes you are the pigeon, most of the time the statue.
posted on 28/12/14 at 09:59 AM Reply With Quote
I've just bought some of these:
3 Colors LED Round Reflector Brake Stop Marker Light Indicator Truck Trailer Car
60mm across and 10mm thick. Going to add some small led markers with a nice big led brake strip as well.
