New Topic New Reply
Author: Subject: Brake pipe layout and master cylinder's
Wolf1e
posted on 10/5/15 at 09:23 PM Reply With Quote
Hi guy's
I've been riveting my brake pipe's to the chassis today. Front's and rear's all done but I'm not quick sure about the route to take through the transmission tunnel.
When the kit arrived from mk they where cable tied to the chassis. The rear brake line running through the tunnel is at the top not at the bottom. Can I mount it at the top or is this not a good idea?
I have an adjustable brake pedal box fitted but I'm unsure whether these master cylinder's will be ok to pass the iva test?
Any feedback would be great.
Thanks guys
Regards
Ian
Andybarbet
posted on 10/5/15 at 10:36 PM Reply With Quote
I too am interested in the best place to run brake lines through the tunnel, as for the master cylinders, I am pretty sure they all need sensors in the caps, ive gone for remote reservoir as it came with the sensor in the lid.
joneh
posted on 11/5/15 at 06:58 AM Reply With Quote
Not built an MK but that pipe that looks like it's routed under the lower wishbone (4th pic down) doesn't seem right to me...
40inches
posted on 11/5/15 at 07:45 AM Reply With Quote
I have run both brake and fuel along the top of the tunnel, easy to get at and see.
Brake line
Brake line
CosKev3
posted on 11/5/15 at 08:03 AM Reply With Quote
As above, you need sensors for brake fluid level for IVA, and the pipe under wishbone looks wrong.
I would say you need another P clip on the drivers side front pipe too just behind the shock mounting, in same position as the one you've put on pass side.
Personally I would add more P clips in the spaces you have left.
Wolf1e
posted on 11/5/15 at 09:30 AM Reply With Quote
Thanks for the replies.
The only reason I have run the o/s/f brake pipe under the wishbone mount is I have seen others do it and also seen a factory built mk with it mounted like this but I thank you for your input.
I will mount the tunnel brake pipes where they are then. Thanks "40inches"
So I don't need to buy see through cylinders then?
Is there a sensor kit I can get to put into the brake cylinder caps?
Thanks again for the replies
Regards
ian
joneh
posted on 11/5/15 at 09:46 AM Reply With Quote
Car builder solutions do one:
http://www.carbuildersolutions.com/uk/brake-fluid-reservoir-cap-with-2-pin-plug-and-fly-leads
dubzter
posted on 11/5/15 at 12:00 PM Reply With Quote
Sorry can't help with your questions but have to say I love the colour scheme you've got going on
_______________________
Blog
Facebook Build Thread
Haynes Forum Build Thread
Locost Builders Build Thread
greed1
posted on 11/5/15 at 09:46 PM Reply With Quote
Im with dubzter and is the colour scheme I am planning for mine after the rebuild and now I've seen yours I will definitely be going ahead with it.
Keep up the good work
Drive it stright sideways
loggyboy
posted on 12/5/15 at 06:29 AM Reply With Quote
See thru cylinders will satisfy 1 part of IVA relating to easy display of fluid level to driver, but you would still need a way to warn of hydraulic failure, which would need either a pressure sensor or a fluid level sensor anyway.
Mistral Motorsport
Wolf1e
posted on 12/5/15 at 10:14 AM Reply With Quote
So do I need clear cylinders or can I get away with just having the level sensors?
Thanks guys for the comments on the colour scene ;-) it is in your face but that's what I was trying to achieve.
I will post a build tread up when I get chance.
I would also like to say that this forum has been great with friendly knowledgeable people that are willing to help others out.
Regards
Ian
loggyboy
posted on 12/5/15 at 11:54 AM Reply With Quote
No you dont need them if you havd level sensors.
Mistral Motorsport
New Topic New Reply
