Author: Subject: Duraflex steering rack clamps?
Nickp
posted on 10/7/15 at 12:08 PM Reply With Quote
Anyone used these instead of the usual alloy or steel versions?
Dodgy? Waste of time? Why would you? Opinions please?
Haynes Locost Roadster Orange steering rack Clamps in Duraflex Extreme Poly
DW100
posted on 10/7/15 at 12:15 PM Reply With Quote
I assume there is a steel bit to go over the top?
If not you might as well hold the rack on with a couple of rubber bands.
Nickp
posted on 10/7/15 at 01:09 PM Reply With Quote
Nope, that's in place of everything that'd normally be there.
I presume they're a very stiff nylon, but I know what you're saying
[Edited on 10/7/15 by Nickp]
Bluemoon
posted on 10/7/15 at 05:18 PM Reply With Quote
"exceptional resistance to tear"
So they can tear then.. I would not be happy with that..
Nickp
posted on 10/7/15 at 05:44 PM Reply With Quote
But it is exceptional, which is better than good
Is there an advantage anyone can think of? They'd put less stress on the surrounding rack mount / chassis maybe because they'll flex if they get a big hit?
Sam_68
posted on 10/7/15 at 06:17 PM Reply With Quote
For our sort of cars, I'd be using a solid machined aluminium rack clamp, to get rid of the flexible bit (the bush), not getting rid of the steel bracket and making it all flexible!
Nickp
posted on 10/7/15 at 06:25 PM Reply With Quote
Fair enough. I've got 3 choices so I'm after different opinions
AvonJas
posted on 10/7/15 at 08:55 PM Reply With Quote
I tried these, they don't really work. You still have to use part of the rubber bush between the rack and chassis mounts. Changed to solid alloy ones instead.
