Author: Subject: Wide track Avon coil overs?
locost7-online.com
posted on 12/7/15 at 09:49 PM Reply With Quote
Just finished off my front wishbones, 45mm wider each side, do I go with the standard tiger coil over and move the bottom coil over bracket inboard to match the original dimension of the wishbone or do I move the bottom bracket out to suit the 45 mm wider and use a different coil over length?
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
laptoprob
posted on 13/7/15 at 06:58 AM Reply With Quote
I used the old shockers and uprated to 400lbs springs. Car spent most of its days on track and handled great.
http://www.youtube.com/watch?v=ajlF4nWJtGA
locost7-online.com
posted on 13/7/15 at 08:40 PM Reply With Quote
Thanks laptop, I just wanted confirmation I will be doing the same
locost7-online.com
posted on 15/7/15 at 08:10 PM Reply With Quote
Another question about coil overs, are the tiger ones fitted with rose joints? The brackets seem to be a bit skew with each other top to bottom on chassis and lower wishbone, the bracket is dead centre of the lower wishbone
laptoprob
posted on 17/7/15 at 06:58 AM Reply With Quote
No they aren't and yes they are skew on all the Avons i've seen. If you havent bought any yet i'd advise some Protech versions as they are the same money but much better quality...and they are rose jointed
ChrisLeary
posted on 17/7/15 at 07:07 AM Reply With Quote
Just a quick one about the shock mounting points... when I put the shock in the mounts, there is a definate twist I have to put onto the rubber mounts in order to get the bolts through top and bottom. Is this due to the misalignment you're talking about above?
Chris.
Don't force it! Get a bigger hammer...
