Author: Subject: Zetec cooling link pipe needed
wombat
posted on 23/2/16 at 01:31 PM Reply With Quote
I'm looking for a supplier or someone to make me a link piece for my bottom rad hoses.
Polo rad to 2.0 Silvertop
32mm OO main pipe with 16mm and 19mm OD outlets.
Can anyone help or is there a way to do it that I've missed???
loggyboy
posted on 23/2/16 at 01:50 PM Reply With Quote
Closes Ive found is these as was after similar set up. try reducers in line to drop from the 25mm
New ASH Fabrications Aluminium Dump Valve Connecting T Piece To Suit Pipe Alloy
[Edited on 23-2-16 by loggyboy]
Mistral Motorsport
MattD
posted on 23/2/16 at 02:14 PM Reply With Quote
http://www.carbuildersolutions.com/uk/black-nylon-stepped-t-piece-1915mm-1512mm
http://www.carbuildersolutions.com/uk/32mm-welded-aluminium-tee-with-15mm-outlet
HowardB
posted on 23/2/16 at 02:35 PM Reply With Quote
the original Zetec pump outlet pipe has an additional outlet for the bypass, that reduces the number of adapters by 1,. then it would be possible to T from that?
Howard
wombat
posted on 23/2/16 at 02:43 PM Reply With Quote
Howard ??
My waterpump only has one large outlet....
wombat
posted on 23/2/16 at 02:45 PM Reply With Quote
Sorry Howard, just read that again properly !
The Mondeo/Focus rubber pipe has an outlet, I get it now.
Bugger and I bought the Tiger silicone one grrr..
HowardB
posted on 23/2/16 at 02:50 PM Reply With Quote
yep,.. I kept mine, made plumbing in the bypass circuit very simple.
I have some 32 OD Ali pipe if you need, I bought 5m as it was least cost. I can put some sort of return on it an post it for small beer too,..
Here is one that I did earlier with a collar heat shrunk on it,...
hose_sensor
hose_sensor
Howard
