New Topic New Reply
Author: Subject: edge trim
Wolf1e
posted on 24/4/16 at 09:07 PM Reply With Quote
edge trim
Hi guys
What edge trimming have peps used for iva around cycle wings, seats and suspension holes in side panels? I have some u channel stuff with adhesive in it but it doesn't take to going round tight corners very well like on the mk cycle wings.
Wolfie
LBMEFM
posted on 25/4/16 at 04:57 AM Reply With Quote
I used the plastic black trim used in door shuts on my MK front wings and seats etc, it has metal clips inside that grip OK on the tight corners. It stayed on for two or so years, then I only took it off the wings as I prefered them without it and as there was no glue involved this was very easy.
theduck
posted on 25/4/16 at 05:24 AM Reply With Quote
I bought some caterham cycle wing trim. Did the job very nicely.
russbost
posted on 25/4/16 at 08:14 AM Reply With Quote
This
link
is what we use on the Furore wings for IVA, we add a spot of superglue every few inches as we don't remove it after IVA
posted on 25/4/16 at 09:18 AM Reply With Quote
IIRC I used rubber glue-less U trim for the cycle wings and some other edges. It went through the SVA OK without a fail.
SteveWallace
posted on 25/4/16 at 11:29 AM Reply With Quote
Originally posted by russbost
This
link
That's what I used and the IVA guy didn't even give it a second glance. By the way, the rubber over the wing stays is two layers of wide diameter electrical heat shrink insulation and the cover on the top ball joint is off a wiring loom in the scrappy.
Toprivetguns
posted on 25/4/16 at 07:51 PM Reply With Quote
I purchased the U channel trim from CBS. A tad pricey however really good with the self adhesive glue. Trick is using a heat gun on a very low setting which softens the rubber enough to manipulate. I've used it on the sharp edges on the headlight mounts for my MK Indy.
Only drive as fast as your angel can fly... !
New Topic New Reply
