Author: Subject: Electrics help please - be kind
wombat
posted on 8/5/16 at 12:14 PM Reply With Quote
Hi guys,
Great to be out in the garage in shorts and a t shirt and making some good headway !
So my build is really gaining pace now and I'm trying to match up my electrical pieces in the hope of a fire up in the not too distant future.
I have a standard Tiger loom + MS2 with the loom and sensors + DigiDash 2
So not the standard fitment and I'm doing ok but got a bit stuck with water and oil connections.
Water first.
I have an inline connector for the MS loom situated on the 32mm outlet from the stat housing = all good.
There is a sensor or Seder on top of the black plastic housing with two wires = Brown + White/Green
Tiger loom has one wire = Green/Blue stripe
Gauge wires for Tiger dash x3 = Red + Black + Green/Blue
Digi Dash just needs the one wire ?
Oil = major confusion .....
So the engine block (2.0 Silvertop ) has a sender/sensor on the intake side with a round pin connector.
Tiger loom has cable for Oil Pressure sendor = White/Yellow
Gauge warning light= White/Brown
Gauge Oil Pressure = Red + Black + Green + White\Yellow
DigiDash requires a one wire feed for Oil Pressure Gauge and Low Oil Pressure Switch ??
Any help appreciated after you have enjoyed blatting around in the sun.
Hope it keeps up all week as I've got my ARDS on Wednesday #fingerscrossed
Schrodinger
posted on 9/5/16 at 07:59 AM Reply With Quote
you could try on the Tiger Owners Club forum http://www.tigerownersclub.co.uk/forum.html there is a guy on there who did the wiring diagrams for tiger as well as people from tiger who might be able to help.
Keith
Aviemore
wombat
posted on 9/5/16 at 08:54 AM Reply With Quote
Well as has been said many times before on here, walking away and going back to the job later often works.
Trouble was I didnt leave it long enough before going back to it !
So i have solved these issues now with the exception of one regarding the oil pressure which I will start a new post for.
Getting there....
