Author: Subject: Most compact engine? Fireblade or r1?
Squadge
posted on 2/8/16 at 06:31 AM Reply With Quote
Hi everyone, does anybody know which is the smallest and more compact engine out of the blade and the r1?
adithorp
posted on 2/8/16 at 07:51 AM Reply With Quote
Depends on the year/version you're thinking of.
http://jpsc.org.uk/forum/
Squadge
posted on 2/8/16 at 07:53 AM Reply With Quote
The r1 I was looking at is the 5jj, but a 2004 blade engine has come up as well,
Minicooper
posted on 2/8/16 at 08:40 AM Reply With Quote
From what I have seen and owned the smallest overall package is the R1, but the cbr1000rr could be even smaller if you replace the sump and do something with the double injector setup on the cbr1000rr, both of which Andy at AB Performance can help you with
adithorp
posted on 2/8/16 at 08:45 AM Reply With Quote
I'd agree with that though don't think "doing something with secondary injectors" is cheap and they do make it very tall otherwise.
daniel mason
posted on 2/8/16 at 09:18 AM Reply With Quote
5jj is a good strong motor.and cheap. Mine in my jedi has proved very strong indeed. 100% reliable and setting trap speeds that no other 1100cc have managed in class this year.
On the flip side to that, my jedi is light and also runs much less wing than some of the cars in class!
If you can keep the weight down.a 5jj should give you decent peflrformance.if not a 2006 5vy yamaha would be my choice
motorcycle_mayhem
posted on 2/8/16 at 02:11 PM Reply With Quote
Nothing, from my experience (worth nothing), is as tightly packaged as an R1. No issues with huge airboxes, secondary injectors, oil surge, rods breaking. It has chocolate gears, but unless you're racing the thing on slicks and/or being a total animal, they do survive reasonably well. The dogs are simply the icing on the chocolate. Don't be tempted to bore the thing, the blocks crack.... but (of course) they won't when you and others do it, only happens to me.
Huge driving difference between the earlier carb'd version - through to the semi-carb'd versions - through to the 5VY/4C8. 2004-6 (5VY) is what you want.
Squadge
posted on 2/8/16 at 05:27 PM Reply With Quote
You say issues with secondary injectors, do they cause problems?
motorcycle_mayhem
posted on 2/8/16 at 05:58 PM Reply With Quote
No... but they usually sit on top of airboxes, making a tall engine errr..... taller. I mentioned that only because you're indicating that space is an issue.
Whereas the pre-2008 GSXR's were 'flat' and rather long, they're now 'stacked' and taller. Hondas are generally quite tall beasts, money will rectify some of the height issues, but if you don't want to spend money... best look at the R1.
