Author: Subject: locating the ECU
emwmarine
posted on 10/3/18 at 03:21 PM Reply With Quote
locating the ECU
I'm installling an ME221 ecu on the dax. The instructions suggest putting it inside the car and passing the cable through the bulkhead. I was thinking of putting it in the engine compartment on the top of the bulkhead for easier access. Are there any issues with doing this?
Building a Dax Rush.
DW100
posted on 10/3/18 at 04:35 PM Reply With Quote
Many ECUs are not water proof so need to be protected from the elements.
If you drive through a puddle the engine bay can get pretty wet
Dale
posted on 10/3/18 at 06:18 PM Reply With Quote
I am looking at putting my speeduino ecu in the back or boot I guess. I have the factory one under the scuttle and its just too hard to get at even when the car is on a hoist. I can waterproof an area back where it will be easily accessable.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
40inches
posted on 11/3/18 at 12:43 AM Reply With Quote
I put mine behind the bulkhead, the Megasquirt has the comms cable fitted into the glove box.
emwmarine
posted on 11/3/18 at 12:12 PM Reply With Quote
Looks good. I think I will make a waterproof case on the scuttle.
AlexXtreme
posted on 12/3/18 at 09:41 AM Reply With Quote
I had an Omex ECU that was located in the engine compt and after a few years it developed a fault.
Omex repaired it (for a reasonable fee) and asked where it was located... it turns out that the heat generated in the engine compt can damage the ecu.
