Author: Subject: Tiger Avon Boot Dimensions
L1berator
posted on 24/7/18 at 02:04 AM Reply With Quote
Morning, All,
I wonder if someone could be so kind as to provide the measurements for the Tiger Avon boot lid and boot. What I'm looking for is the width and length of the boot lid, then the depth of the boot and also the measurement from front to back and side to side across the bottom of the boot. I know the front and back (and the sides) of the boot slope inwards so that the base of the boot is smaller than the boot lid.
I've sent the bodywork away for paint so can't take the measurements from my own tub, but would like to fire up Autocad to design some swan neck hinges ready for when it gets back.
Thanks,
Peter
RedAvon
posted on 26/7/18 at 08:25 AM Reply With Quote
Hi Peter,
Boot lid (measured from new unused) 71cm x 26.5cm.
Bottom is 68.5 cm. However my car is part built and the previous owner cut out most of the bottom of the boot but I have measured the part that is left . I imagine the other dimension would have the same taper and 24cm would be about right.
Hope this helps.
Ian
Bricoleur
L1berator
posted on 26/7/18 at 04:13 PM Reply With Quote
Hi Ian,
Thanks very much for the measurements.
Regards,
Peter
RedAvon
posted on 27/7/18 at 08:05 AM Reply With Quote
Hi again Peter,
I realise i forgot the depth of the boot measurement you asked for. This is 16.5cm.
Ian
Bricoleur
L1berator
posted on 28/7/18 at 03:19 AM Reply With Quote
Thanks Again, Ian - much appreciated...
Regards,
Peter
