Author: Subject: Mounting Avon Wiper Motor
Ferg
posted on 6/8/08 at 05:06 PM Reply With Quote
A friend of mine is stuck with how to mount the Avon Motor. He's done the wiper rack tubes and boxes, but is confused by how the motor sits.
Anyone got a photo????
Ta!
snippy
posted on 6/8/08 at 08:52 PM Reply With Quote
pic of wiper motor fitted
There should be a `U` shaped bracket that fits around the wiper motor body which is then simply held in place with a short bolt each end through the scuttle bulkhead. The attached pic is off my own Tiger Cat before I slipped on the tubes. On mine the motor is fitted on the passenger side of the scutle. Small tip - you can change the direction the wipers park by rotating the wheel boxes 180 degrees! Hope this helps your friend.
Nick
snippy
posted on 6/8/08 at 08:56 PM Reply With Quote
pic is too big to attach so I have uploaded it into my archive under heading `heater guide fibreglassed`.
Nick
posted on 6/8/08 at 09:24 PM Reply With Quote
Snippy- have you used the proper bundy outer tube or are you just using the inner tube and not bothering with an outer????
I mounted mine on a welded up mount (there's a rough diagram in my photo archive). I promised I'd take some photos of the mount but haven't yet (but I will honest!!!)...
[sorry snippy, I should really learn to read before asking stupid questions!!!]
[Edited on 7/8/08 by BenB]
Gary Symons
posted on 7/8/08 at 12:38 PM Reply With Quote
Ta!
These any use:
http://homepage.ntlworld.com/gary.symons/buildphotos/12-windscreen&wipers/pics/pic14.jpg
http://homepage.ntlworld.com/gary.symons/buildphotos/12-windscreen&wipers/pics/pic22.jpg
posted on 7/8/08 at 01:13 PM Reply With Quote
This is how I did mine:
welded up a bracket which bolts on the lower footwell rail. Bolts (with spacers to hold the bracket off the scuttle upright) at the top.
wiper motor on bracket
Ferg
posted on 7/8/08 at 06:34 PM Reply With Quote
Great stuff, guys!!
Thanks loads!
F
