Quaife reverse 'box
StuartA - 5/2/03 at 05:07 PM
Looking to fit one of these gizmos in our car. Anyone have good / bad / indifferent things to say about them?
What is the going rate for them? Seen them new for about £600 but would like to know if anyone sells them cheaper.
Jon Ison - 5/2/03 at 05:19 PM
personaly i would,nt fit any mechanical reverse, if i felt the need i would go electric, there as been many a disscussion on these on here and the BEC list, people have run them with no problems, but i am yet to be convinced...............
your call
ChrisGamlin - 5/2/03 at 06:55 PM
Totally agree with Jon, if you can get away with it, do without altogether (I have, its no real hassle). If you really need a reverse, go for an electric one like MKs one, or from Gordon Griffin on the Yahoo BEC list. The mech ones always leak at best, add vibration into the drive-line, and generally are not very reliable.
Chris
Jon Ison - 5/2/03 at 06:58 PM
and have been known to put the odd hole in the trans tunnel..............
like i said, some peolpe have run them trouble free, but IMO there not there yet..
StuartA - 5/2/03 at 08:40 PM
Thanks for the advice guys. Had a chat with andyd earlier and we have decided to go without until at least post SVA. That way we can get the car on the road and see if it presents any problems. Then maybe put the reverse box in later.
Does anyone have any pics of how the MK electric box mounts. It isn't very obvious from the pic on their website. We would like an idea of options other than the Quaife so that we know what bits we might need access to post-SVA.
ChrisGamlin - 5/2/03 at 11:31 PM
As far as I know, the MK one mounts on the Sierra diff and drives a sprocket bolted onto end of one of the driveshafts, but other than that, I'm not sure. Gordon Griffin's one drives a sprocket on the engine end of the prop, but is primarily designed for a blade engine, so might need adapting or checking for fitment if other engines are used.
Chris
alainmengoli@hotmail.com - 6/2/03 at 11:07 AM
I would not recommend it, I have had many friends return the unit as they always tend to break. To be honest most of the car that use them are soo light a little push would do the job (which make me wonder why they break, mustne poor design casting). You also loose some hp with it.
Better spending the money on good brakes and suspension.
Alain
mdc124 - 15/2/03 at 12:32 AM
pics in my archive and on http://www.farend.co.uk/indyblade.aspx
If you want closer or bigger pic - mail me
[Edited on 15/2/03 by mdc124]
Jon Ison - 16/2/03 at 10:28 PM
just to back up the theory, this was posted on the BEC list tonight....
Then, 30 miles from home the Busa started vibrating really badly.
Then clonk! Clank! Clonk! Bang! And no drive - something major has
broken in the Reverse Gearbox. Fortunately it's only done 1000 miles
and should still be under warranty...
Nuff said........
Barker - 11/3/03 at 12:27 PM
I've got a mech one from Stuart tayor chain drvien diff with inner ring and a starter motor for the drive - much lighter than full box got mine second hand - £200 I think
StuartA - 11/3/03 at 01:37 PM
As this subject has re-appeared thought you might like to know we decided to do without for the time being, for all the reasons mentioned so far plus the major contributing factor... cost. We have spent far too much already and the extra £600 would not go down to well. Just got to remember to avoid places where reversing is a necessity!
