Author: Subject: Carb question - what is this for
Banana
posted on 13/4/17 at 09:17 PM Reply With Quote
I noticed the diaphragm seems to be pinched on one of my carbs around the area highlighted in the picture.
What does that hole/jet do?
r1_pete
posted on 13/4/17 at 10:15 PM Reply With Quote
Long time since I worked with cvks but Im sure its the vacuum port which raises the diaphragm / throttle slide.
dd1972
posted on 14/4/17 at 07:03 AM Reply With Quote
Spot on as this man says.
britishtrident
posted on 14/4/17 at 08:23 AM Reply With Quote
Yes a depression port it has the same purpose as the holes in an SU or Zenith-Stromberg CD piston.
[/I]
Banana
posted on 14/4/17 at 08:38 AM Reply With Quote
Thanks guys, the Haynes book doesn't actually make any reference to it.
Im hoping that is the cause of the hesitancy at full throttle im getting..
r1_pete
posted on 14/4/17 at 11:03 AM Reply With Quote
If there is any leak around the diaphragm seal you will get poor running, I used to put a layer of ruberlube in the recesses where the bead seats, keeps the rubber supple, and has a slight swelling property, so ensures a good seal, and makes future removal easier.
