Author: Subject: How to read connector plans on Yamaha wiring loom?
TimC
posted on 5/7/18 at 06:52 AM Reply With Quote
Good Morning All,
I’ve got to wire a new connector for the original Yamaha clocks - I’m doing this to read fault codes.
Rather than spend £50ish+ on a clock loom, I’ve managed to buy a new plug with terminals for £6 that I just need to wire.
If I look at the diagram, I see this:
Clock Plug
Clock Plug
What I want to know is, does the diagram reflect the plug as I push the terminals in from the back? Or, is it as viewed from the connecting end of the plug?
Any help appreciated.
T
Davg
posted on 5/7/18 at 07:14 AM Reply With Quote
Hi Tim your pic is view from front of plug . So wires inserted to back. Cheers D
TimC
posted on 5/7/18 at 07:22 AM Reply With Quote
Thank you. Just to be absolutely clear, then - as I look at this:
Plug
Plug
bottom right will be light blue with a white tracer?
Davg
posted on 5/7/18 at 07:31 AM Reply With Quote
Can't see this pic too clearly. Whether this is the back or front of plug. Blue/Wh will be neutral and when plug is in clocks looking into back of clocks will be bottom left.
Davg
posted on 5/7/18 at 11:21 AM Reply With Quote
Tim just for total clarification, your first pic with colour codes of plug is upside down when you insert into clocks the tab is at the bottom.
The pins are actually numbered 1-16 So viewing the plug from the back as you would be inserting into clocks should be pin 1 bottom left red/green
pin 8 bottom right yell/blk
Pin 9 top left blue
Pin 16 top right blue/wh with others per pic. Assume you know what the colours relate to. Cheers D
TimC
posted on 5/7/18 at 12:57 PM Reply With Quote
Great - thanks so much for taking the time to walk me through this.
Yes - I know what colours I need - I just wasn’t sure where to put them and didn’t want to fry my new (to me) clocks finding out.
Thanks again
adithorp
posted on 5/7/18 at 01:41 PM Reply With Quote
Don't forget you need the kill switch as well to access the fault codes and test facilities.
http://jpsc.org.uk/forum/
