Author: Subject: CBR1000 After Market ECU
DANMAN
posted on 23/9/20 at 11:55 AM Reply With Quote
Hoping someone may be able to help here. I have had an absolute turd of a time trying to get my 2005 CBR1000 engine to run properly and be able to fit under the bonnet which meant having to make a new curved intake and trumpets and side mount the secondary injectors.
After three different intake runner setups I can't get it to run right as it leans out big time after about 7k so basically I am at a point where I'm thinking of ditching the whole secondary setup and just running bigger primary injectors with a standalone ECU.
Has anyone else been down this path before and if so what ECU did you use?
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
OliverJamesThomas
posted on 25/9/20 at 04:33 PM Reply With Quote
I’m currently going through all this at present, with a Fireblade engined Phoenix. It is a race only car, so I am looking to build a new stand alone engine loom that will allow for HISS, etc, to be binned. I have a similar plan of rotating the air box to get rid of the current bonnet bulge that is difficult to see past.
There are a few ECU options available from the likes of Syvecs and Link that will run the primary and secondary injectors, but the one bit of information I haven’t yet found is the crank trigger pattern. Knowing that would possibly allow other models of ECU to be considered, but the information doesn’t seem to be available anywhere. I think I’m going to have to resort to a physical inspection when I return from working away.
