Author: Subject: First drive and progress update.
twybrow
posted on 2/1/09 at 07:01 PM Reply With Quote
Well, after much scratching of beards, and plenty of checking all the wiring, I finally got my engine running (it needed a good charge of the battery, and a new can of fuel).
Here are some of the pictures (and a very smiley me)....
The first is me faffing around trying to figure out why it wouldn't work.
Why will it still not work?
Finally got the engine running, and moved the car under its own steam....
She works!
She works!
And finally, this morning I took it for a brief run down our 'private road'.... Link to youtube here.
Below are a few more update pictures. I have now completed the dashboard, and made myself a carbon fibre airbox (which looks like a travel/vanity case!) to eliminate some of the induction roar. I havce also fitted one of the two side panels on, and bent the 2nd in place. I have fitted the propshaft (hence the drive), and even found time to get the speedo (Koso) reading the speed from the propshaft.
Happy me - she moves!
Dash closeup
Dash closeup
Dash 3
Dash 3
Progress as of 01/01/09
I'm still pushing hard for SVA before the dreaded IVA comes into play. I am happy with progress at the moment (althought the Mrs is fed up!).
Humbug
posted on 2/1/09 at 07:05 PM Reply With Quote
Who set the headlights - Marty Feldman?
Howlor
posted on 2/1/09 at 07:06 PM Reply With Quote
Looks really nice build, good feeling the first drive. Love the minilites.
twybrow
posted on 2/1/09 at 07:24 PM Reply With Quote
That's after I adjusted them, they were pointing at each other! The Mrs likes the 'Brum' look....
dean100yz
posted on 2/1/09 at 07:28 PM Reply With Quote
Looks sweet. Bet your well chuffed
Dave Ashurst
posted on 2/1/09 at 07:45 PM Reply With Quote
Looks great, U2U sent.
Dave
speedyxjs
posted on 2/1/09 at 08:22 PM Reply With Quote
Very
Keep up the good work
Dangle_kt
posted on 2/1/09 at 08:24 PM Reply With Quote
looks great, but that start stop button won't pass the sva will it?
is the doomsday switch radiused enough?
YQUSTA
posted on 2/1/09 at 09:15 PM Reply With Quote
Very nice
The dash looks like 1 I have
keep up the good work
YQUSTA
gavin174
posted on 2/1/09 at 09:51 PM Reply With Quote
start/stop panel should be ok
its within the exemption zone..
117mm from edge of steering wheel i think..
twybrow
posted on 2/1/09 at 10:20 PM Reply With Quote
Thanks for all of the comments. Much appreciated.
All of the switchgear should be within the exempt zone. More of a concern to me, is the area under the dash, which I was hoping to cover for SVA, but I might end up just padding everything instead....
