Author: Subject: OT - diesel fuel pump for a 406 HDI 1999 2ltr
Mr Whippy
posted on 12/5/09 at 12:25 PM Reply With Quote
Hi
One of the guys at works been quoted silly money for a new pump being fitted - £1000
Unfortunately he knows no better and can’t fix it himself, anyone got one lying about or know a good garage or pump specialist in Aberdeen that will not rip him off.
brianthemagical
posted on 12/5/09 at 12:52 PM Reply With Quote
High or low pressure?
Mr Whippy
posted on 12/5/09 at 12:54 PM Reply With Quote
not sure but the HDI possibly means high?
brianthemagical
posted on 12/5/09 at 01:22 PM Reply With Quote
The HDi high pressure pump is high, but the low pressure pump is low. It really depends which one is dead, as the low pressure pump takes 10mins and less £100 to fix.
dinosaurjuice
posted on 12/5/09 at 01:29 PM Reply With Quote
the low pressure is usually the one that goes.
the high pressure pumps are very reliable, but theres always the exception.
minordelay
posted on 12/5/09 at 01:31 PM Reply With Quote
Plenty of these engines in the breakers now and if it's the high pressure pump, it can be changed in less than a hour with some common sense.
Mr Whippy
oh right, its the high pressure one on the engine (personally I don't do diesels unless its on my digger)
zzr1100rick2
posted on 12/5/09 at 03:50 PM Reply With Quote
Auto data reckons 5.8 hrs for pump dont know if thats right thou ?
eccsmk
posted on 12/5/09 at 05:28 PM Reply With Quote
link
and another
here
minordelay
posted on 12/5/09 at 08:58 PM Reply With Quote
The labour time would include replacing the cambelt. They should be done every 96k. But the pump can be changed without interfering with the belt, the pump doesn't need timing as it only generates pressure. You could learn the best way to do it on the doner in the scrappy, honestly.
