Author: Subject: SP1 instruments?
megablade_andrew
posted on 21/8/02 at 10:29 PM Reply With Quote
SP1 instruments?
Can SP1's LCD tacho correctly display fireblade revs? SP1 is a V4 but dont know how the sender works?
Jon Ison
posted on 22/8/02 at 04:10 PM Reply With Quote
i used these........
http://www.customautotech.co.uk
search the site you will even find a few pics of me motor....
Jim
posted on 22/8/02 at 08:28 PM Reply With Quote
I used a standard 98 fireblade console mounted centrally on the dash. only problem was it was rather expensive (160 second hand as apparently not many survive the accidents, apparently 400 ish new). It looks ok but the speedo is not working so i have had to use one that is for motorbikes. It will reads up to 180 ish mph. Should just about be fast enough
megablade_andrew
posted on 23/8/02 at 04:31 PM Reply With Quote
The 98 blade clock should work with a yellowbox. Does the 98 blade console contain all the warning lights, temp gauge etc? Where can i get a glimps of these online?
Jim
posted on 23/8/02 at 05:01 PM Reply With Quote
The clocks have the direction indicators, the dials light up with the lights to show that they are on. There is a main beam indicator. Also they have a neutral light, oil pressure light, digital temperature readout, trip distance and a and b trips. No idea where you can see one online, they are in Haynes manual.
THis place has one for sale. I got mine from there
http://www.cheshiremotorcyclesalvage.com/acatalog/Online_Catalogue_CLOCKS_AND_INSTRUMENTS_82.html
Jim
Jim
posted on 23/8/02 at 05:38 PM Reply With Quote
If you live any where near sheffield you could come and look at my dash
Jim
megablade_andrew
posted on 23/8/02 at 09:48 PM Reply With Quote
fraid not, live in shetland islands, near north pole!
