Author: Subject: air box
shorts
posted on 19/10/10 at 12:02 PM Reply With Quote
air box
Hi All
I'M building an mk with a 2008 R1 motor, has anyone got any pictures or ideas about a plenium chamber that have been custom made,
update on the build is engines in and running that was a relief. thanks malc
cheers
Dave
[Edited on 19/10/10 by shorts]
matt_gsxr
posted on 19/10/10 at 01:12 PM Reply With Quote
what kind of engine? or is R1 the default these days?
I built an airbox from folded aluminium, which I like.
Air_box_installed
Air_box_installed
It is big (to slow down the air), includes a filter, has a cold air feed from the front of the car, and secondary injectors.
http://www.locostbuilders.co.uk/viewthread.php?tid=137002
Also its got a window so I can see the fuel firing in.
I get higher MAP values than I did with the old suzuki airbox, so it seems to work. Subsequent to the thread I have insulated it with a sheet of aluminized bubble wrap, and the air temps go to about 4deg C above ambient. I could improve it further with a better feed pipe (i.e. insulated).
Some folk build them out of fibreglass, but I was worried about the fuel from the secondaries getting onto it.
Matt
cosmick
posted on 19/10/10 at 01:25 PM Reply With Quote
Which 2008 motor are you using? Suzuki,Yamaha,Honda, Kawasaki?
If it is a 2008 engine, one would assume that it is injected.
If it can't be fixed with a hammer then its probably an electrical problem.
shorts
posted on 19/10/10 at 05:53 PM Reply With Quote
air box
ITS A YAMAHA R1
hicost blade
posted on 20/10/10 at 04:38 PM Reply With Quote
Air_box_installed
Air_box_installed
Matt
That is a rather nice air box, and without the need for any welding, I'm very impressed
