Author: Subject: brake problems on R1
corrado vr6
posted on 31/10/10 at 04:11 PM Reply With Quote
Afteroon all im in need of some help on with my wiring on my 06 r1
basically i thought i had everything sorted but have noticed my brake lights have stopped working, now there are a couple of reasons why i think this has happened but i need some help ruling something out. I fitted an immobilisor the other day which involves removing the ignition wires from the r1s fuse box but i have noticed that the brown/blue wire from G also goes to the Ignition wire B obviously now i have removed the brown/blue wire from B could this affect my brake lights?
wiring
wiring
If its not this then it could be my brake light switch has broken but want to rule out other things first is there a way of testing the switch without taking it out of the braking lines as would rather avoid having to bleed the system.
Seriously appriciate any help Greg
http://r1indy7.wordpress.com/
A1
posted on 31/10/10 at 04:25 PM Reply With Quote
try wiring it back in as it was, if it works then youll know its the immobiliser.
posted on 31/10/10 at 04:37 PM Reply With Quote
Take the wires of the switch and connect them together, if the light comes on the switch is fact
matt_gsxr
posted on 31/10/10 at 05:09 PM Reply With Quote
if its a pressure switch, then I'd put my money on it being broken.
Definitely check the switch before taking anything else apart.
Matt
