Author: Subject: Fury Fireblade rebuild
zekill
posted on 24/2/12 at 05:17 PM Reply With Quote
Hi all,
I have buy a Fisher Fury lightweight chassis, the build start in 2001 and never finished.
Well, this is a very bad build and need to do a lot of work.
This Fury have a Phoenix bodywork and the engine is a 919 fireblade.
I have pick up the car this tuesday and start job.
My first issue is with the exhaust manifold. It is away from the chassis and the silencer hit the low part of bodywork.
I can't cut the top of manifold because it is so curved.
What you think about this issue ? I need about one inch more near from chassis to have a good clearance to body.
Fisher Fury with Phoenix bodywork, Blade 919cc
Hugh_
posted on 24/2/12 at 05:25 PM Reply With Quote
If it's a repackable silencer thats accessed for the rear of the silencer, have you tried removing the outlet end and then rotating the body to see if that gives you any more clearance? If not I'd just cut and re-weld the inlet into the silencer such that it doesnt foul the bodywork.
Good luck the project, I still miss my Fury Fireblade
zekill
posted on 24/2/12 at 05:50 PM Reply With Quote
this is the distance that is too long for about one inch.
watsonpj
posted on 24/2/12 at 11:08 PM Reply With Quote
Mine fits in the side pod but only just. Heres some pictures if you want any more info just ask
sorry the pictures not too clear on this one but its about 30mm overhang
On the overside it lloks like mine is much closer to the chassis rail than yours
and some views inside the side pod
J'espere que ceci aide.
Pete
zekill
posted on 25/2/12 at 05:19 PM Reply With Quote
You're very helpfull and you speak french
After investigation, it seem it's the engine not in place, i must reduce the rear bracket.
i'll do the job this week.
zekill
posted on 14/6/12 at 08:28 PM Reply With Quote
First track day with car, some issues like:
lot of diff oil leak, bad seat, engine run too poor, center proshaft rubber bearing died.
But I'm happy
Fury trackday video here
Nick DV
posted on 15/6/12 at 08:38 AM Reply With Quote
But I'm happy
Doesn't look too bad. Nice little circuit, and I bet no silly noise regulations!
Cheers, Nick
"The force will be with you, always!"
zekill
posted on 15/10/12 at 11:10 AM Reply With Quote
last trackday this sunday, the car work fine now.
video:
http://www.youtube.com/watch?v=jg4IFh2p7mw
and a pic:
enginearin
posted on 15/10/12 at 12:51 PM Reply With Quote
video:
and a pic:
Nice Photo... but you need a higher roll bar!!!
zekill
posted on 16/10/12 at 06:37 AM Reply With Quote
yes, I don't understand why the original roll bar is too low ...
enginearin
posted on 16/10/12 at 10:37 AM Reply With Quote
All the Strikers, Phoenix and Furys that i have come across have has a really low bar (including the two that i have owned)... being 200cm tall this is an issue for me.
My old Phoenix
I've rebuilt the rollcage on my Fury to address the issue properly
zekill
posted on 16/10/12 at 08:47 PM Reply With Quote
the second pic is awesome, thank you for advice.
