Author: Subject: R1/Fazer
trialnick
posted on 15/12/16 at 11:57 AM Reply With Quote
R1/Fazer
Another question. I have removed the original air box to install individual carb filters. Do I block off the pipes that fed to the old air box or leave them to breath to the engine bay ?
Nick
CosKev3
posted on 15/12/16 at 02:23 PM Reply With Quote
Individual fliters will lose you some BHP.
If you want to go open filter you will be better off with a big one piece filter on a backing plate.
The pipes you talk of don't want to be blocked off,just leave them open.
adithorp
posted on 15/12/16 at 03:07 PM Reply With Quote
What year model/engine? Which pipes?
This applies to R15vy motors... If it's the AIS valve pipes out ofthe cam cover you can block them (don't leave open). If it's the crankcase breather pipe from the top of the gearbox it needs to be fed to a catch tank. Also look up the R1 breather issues (lots ofthreads on here about it) and you might want to do the mod' that utilises the AIS housing as a cam box breather.
http://jpsc.org.uk/forum/
trialnick
posted on 15/12/16 at 03:20 PM Reply With Quote
Hi
I have done the AIS removal mod already. From memory its the probably the crank case breather, I was thinking if feeding it to a catch tank or bottle so thanks for the confirmation.
adithorp
posted on 15/12/16 at 03:41 PM Reply With Quote
Originally posted by trialnick
Hi
If you've done the additional can-cover breather via AIS housings mod, then T that and the one off the top of the gearbox together and into a catch tank. Then vent the tank to atmos'
CosKev3
posted on 15/12/16 at 03:48 PM Reply With Quote
Ah it's an injected engine?
Was thinking it was the carbed one
[Edited on 15/12/16 by CosKev3]
trialnick
posted on 15/12/16 at 03:56 PM Reply With Quote
No its carbs
CosKev3
posted on 15/12/16 at 07:04 PM Reply With Quote
So the pipe from the top of gearbox will need to go to a catch can,then the pipes that go to the carbs float chambers can be left open to atmosphere
