Author: Subject: Required clearance around prop
Banana
posted on 4/4/17 at 07:26 PM Reply With Quote
How much should i expect my prop to move from its center line during driving?
Im making a new gear selector, and the bottom of the lever is going to end up 1/2 inch from the prop..
loggyboy
posted on 4/4/17 at 07:36 PM Reply With Quote
Live axel or IRS?
Live - minimal at gearbox end, few mm to suit gearbox/engine mount movement, but lots as it moves to diff at rear depending on suspension travel.
For IRS expect a few mmat front as above and very little at rear if diff is solidly mounted.
I have designed in about 10mm clearance to my prop catchers.
Mistral Motorsport
Banana
posted on 4/4/17 at 08:19 PM Reply With Quote
That is a good point.. I have IRS. However, i would still expect the prop to oscillate slightly.
SJ
posted on 5/4/17 at 07:20 AM Reply With Quote
When I built my MK the supplied prop had a much bigger joint that was standard meaning it hit the chassis when cornering. That was with about 5mm clearance. When it had 10mm clearance it was fine. I think half an inch should be no problem.
adithorp
posted on 5/4/17 at 08:52 AM Reply With Quote
It also depends if you have a one piece prop or 2piece with centre bearing. 2piece will move about a bit on the rubber mounted bearing. You should be able to manually push it about enough to see whether the clearance is enough.
http://jpsc.org.uk/forum/
r1_pete
posted on 5/4/17 at 04:43 PM Reply With Quote
You also need to consider how pliable the gearbox mount is, and the impact of it failing, could the prop hit the underside of your linkage.....
