Author: Subject: what ratchet straps to use?
andyfiggy2002
posted on 18/4/17 at 01:34 PM Reply With Quote
ive bought these
link
but been told that there not good enough to hold down my 400kg car on a trailer, what spec are you other guys using on your lightweight cars?
loggyboy
posted on 18/4/17 at 02:05 PM Reply With Quote
I wouldnt want to use those, look more like luggage jobs.
Spend a few quid and get dediated ones.
Recovery Ratchet ! HI-VIZABILITY GREEN ! Alloy Wheel Safety Straps Trailer 5ton
Mistral Motorsport
ian locostzx9rc2
posted on 18/4/17 at 02:27 PM Reply With Quote
You need 50mm straps they will be rated 2 tonne each or more there not too expensive and if you look after them there last years
[Edited on 18/4/17 by ian locostzx9rc2]
Banana
posted on 18/4/17 at 02:35 PM Reply With Quote
Originally posted by andyfiggy2002
ive bought these
link
They held mine ok.
Assuming you have a few pulling the same direction, the load is spread across them. So they are more than strong enough.
Bluemoon
posted on 18/4/17 at 02:43 PM Reply With Quote
What with insurance company's and accidents I would go for something designed for the job, you could fine yourself in all sorts of trouble otherwise, but only after the event...
posted on 18/4/17 at 02:48 PM Reply With Quote
I use two of those pictured to secure my Clarke 151 MIG welder to a trolley, but I'm not sure I'd secure car with them.
motorcycle_mayhem
posted on 18/4/17 at 03:13 PM Reply With Quote
http://www.brianjames.co.uk/range/accessory_details.aspx?id=5
Nothing Less.
Bought these over 10 years ago, used and stored carefully, they're still working well today.
Camber Dave
posted on 18/4/17 at 05:42 PM Reply With Quote
50mm purpose made straps
To BS standard
5 Ton Each to secure a 400Kg Car
From a British maker of dedicated recovery and lifting equipment
Whats not to like?
Are we looking at the same listing?
andyfiggy2002
posted on 18/4/17 at 05:46 PM Reply With Quote
so many different answers & 5 ton which is 5000kg or over 12 times the weight of the car, surely OTT. Is there not a set of government regs or formula to use or if its just guess work?
[Edited on 18/4/17 by andyfiggy2002]
scudderfish
posted on 18/4/17 at 06:20 PM Reply With Quote
The breaking strain will be along the force directly along the length. If you've strapped a car down, the straps will be at an angle and the force resistance will be less. An accident (or even a bad pothole) will have several G of acceleration which will multiply the weight of what you've strapped down.
andyfiggy2002
posted on 18/4/17 at 06:27 PM Reply With Quote
Ok thanks
found this which might be helpful to others to
linky
bi22le
posted on 18/4/17 at 06:42 PM Reply With Quote
These are pretty much what I bought about 4 years ago. They work a treat and TBH I have used them for other things including tree felling, strapping garden waste to my trailer and lofting my car up after it fell off the trailer. . . .
45 quid is not a lot for some decent straps that stop your car from causing serious damage to other road users.
Please read my ring story:
mark chandler
posted on 18/4/17 at 06:59 PM Reply With Quote
I,ve got 2" lorry straps, had them for over 20 years now and still going well.
It's not the static weight of the car to consider, that's a gentle lift think about what happens if you have to stop suddenly?
If you jump on a weighing scale it will hit double your weight with you only moving at a of couple of miles an hour, break suddenly and your little car mashes into the back of your car to save £20!
john.rigby247
posted on 19/4/17 at 10:42 AM Reply With Quote
I recently bought some 50mm vehicle recovery straps from Damar rated for 5000kgs (link below), excellent quality and they were able to make the choker straps small enough to suit my 13" wheels, very impressed:
http://www.slingsandstraps.co.uk/vehicle-transport-straps/
I hope this helps
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 19/4/17 at 06:33 PM Reply With Quote
I had a couple of those skinny straps but found that they twist up quite easily. However, I was lucky enough to find at the side of the road , at different times several lorry straps which had fallen of trucks and which have served for the last 15 years...Worth stopping for.....
andyfiggy2002
posted on 20/4/17 at 12:05 AM Reply With Quote
Ok will send these straps back & thanks for all the info guys
