Author: Subject: Carbs
Guinness
posted on 19/3/05 at 06:58 PM Reply With Quote
Carbs
Anyone know what these two pipes should connect to?
Pipes
Pipes
Back into the air filter or somewhere else?
So far i know they're not part of the carb warmer system, because the cooling system is sealed and OK. And they are not fuel inlet pipes, because that comes in from the bottom.
Sorry if I'm being thick.
Mike
monkey69
posted on 19/3/05 at 07:07 PM Reply With Quote
Aren't they the fuel vent pipes for the float chambers?
I think they probably are (been taking the coolant pipes off my zx9r carbs today). It might be an idea to lengthen these and point them towards the road in case something goes wrong. They point towards the exhaust otherwise, which ain't too great
Guinness
posted on 19/3/05 at 07:12 PM Reply With Quote
Thanks Monkey, I'll join them with a T-piece and run them down to the road then. Was concerned that they were vacuum pipes or something.
Cheers Mike
Mad Dave
posted on 19/3/05 at 07:32 PM Reply With Quote
Is it the same as this?
Mini M45 outlet flange
[Edited on 19/3/05 by Mad Dave]
Guinness
posted on 19/3/05 at 08:21 PM Reply With Quote
Yes Dave, comes out the top between carbs 1-2 and 3-4.
Where does it go on yours?
Mad Dave
posted on 20/3/05 at 06:36 AM Reply With Quote
I was wondering what to do with this aswell, it just hangs there at the moment
ChrisGamlin
posted on 20/3/05 at 12:11 PM Reply With Quote
As monkey says, I think they are breathers for the carbs which usually breathe back into the airbox. I guess you could put a hole through the sausage filter backplate and breath it back in that way, but I'd be tempted to just route it elsewhere like youve said, or best of all, into a proper catch tank.
Chris
[Edited on 20/3/05 by ChrisGamlin]
