Author: Subject: tyre pressures & weights
loafersmate
posted on 10/2/03 at 10:56 PM Reply With Quote
Could anyone out there who's SVA'd an MK indy blade tell me what weights have you put down on the SVA form??
Also what sort of tyre pressures are you running ? I've got 185/55-14 Yoko A539's
Ben
Jim
posted on 10/2/03 at 11:07 PM Reply With Quote
I had mine SVA'd a while ago. I think the figures from MK blade were 350 front 450 rear for a total of 800 kg. I know the car only weighs under 500 kg but it needs this for passenger and all luggage etc. This is classed as a fail if wrong for SVA so check with other people aswell. Check with MK. Passed brake checks with flying colours with sports discs and pads on front, standard rear discs and pads
I am running 195/50/15 and pressure is at approximately 17 psi front and rear. Originally they were at 30 ish until a visit to MAC 1 and they lowered them for me. also same pressure on A032R 185/60/14. Before at 30 psi it felt very bouncy, seems better at this lower psi IMHO.
Jim
[Edited on 10/2/03 by Jim]
