Author: Subject: what diff is this..
badding
posted on 30/4/06 at 01:22 PM Reply With Quote
what diff is this..
It comes from a '88 sierra 2.0L
[img]Gax rushCIMG0761.JPG[/img] Rescued attachment CIMG0761.JPG
pathfinder
posted on 30/4/06 at 01:31 PM Reply With Quote
That’s just the casting number so wont give you any info on what ratio it is! There should be a small tin tag attached to one of the bolts on the rear of the diff, this will have a letter on it that relates to ratio. It is also marked on the cars vin plate!
Probably a 3.62 non ltd slip
[Edited on 30/4/06 by pathfinder]
badding
posted on 30/4/06 at 01:58 PM Reply With Quote
is says 83BG 4033 BA
RichardK
posted on 30/4/06 at 02:04 PM Reply With Quote
You may find this site useful http://forum.fordsierraclub.co.uk/viewtopic.php?t=5843
mad-butcher
posted on 30/4/06 at 07:06 PM Reply With Quote
the other mounting holes might have been usefull if straight thru 7 inch if threaded odds are 7.5 inch therefore no use on an indy
chockymonster
posted on 30/4/06 at 08:30 PM Reply With Quote
There's another line of numbers on the little tag. They'll tell you the diff details.
posted on 30/4/06 at 08:38 PM Reply With Quote
Just turn the diff input flange and count how many revolutions it takes to comple one rotation of the output.
