Author: Subject: BECs and cats
MK9R
posted on 18/5/03 at 06:25 PM Reply With Quote
BECs and cats
I've heard so many different views/stories i'm very confused over what exhaust system i will need to pass SVA and MOT's.
I have a zx9 C1 (1998) and the current plan is to use a tiger manifold and collector and the bike can. What will i need to do to get through the tests.
[Edited on 18/5/03 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Wadders
posted on 18/5/03 at 08:00 PM Reply With Quote
AFAIK the only 100% guaranteed way to pass emmisions with a post 95 engine, is to hire or buy a closed loop lambda system and cat.
Bought mine from Tiger for £295 + VAT (ouch!) Have heard £120 quoted to hire the same from ST, dunno what others charge.
Sorry
Wadders
i]Originally posted by MK9R
MK9R
posted on 18/5/03 at 09:19 PM Reply With Quote
How does the lambda actually ater the emmisions?
Cheers Austen
RGB car number 9
www.trackace.co.uk
Wadders
posted on 18/5/03 at 09:36 PM Reply With Quote
The lambda sensor is fitted in the collector, it sniffs the exhaust gasses and sends a signal to an ecu which in turn opens two solenoid valves which allow a tiny amount of air to be sucked into the inlet manifolds. sounds complicated, but the system is easy to fit.
cylindersi]Originally posted by MK9R
benedict
posted on 18/5/03 at 09:45 PM Reply With Quote
wrt ST's system that I used, there's an electronic "black box" at the heart of the system. This is connected to the lambda sensor in the exhaust and a temperature probe stuck onto the top hose near the 'stat. It's also connected to 2 air bleed valves. These connect via small air hoses to the takes-offs in the head near the bottom of the inlet throats each one connecting to 2 cyls. (These are the connections that are usually used to balance the carbs and "off the bike" the 1 & 4 are connected to the bike's vacuum valve and 2 & 3 are blocked.)
The control box then pulses the air valves to let in enough air to give the appropriate mixture.
It needs to be adjusted in conjunction with the idle mixture on the carbs but when I did it it worked really well. Oh and of course there's a cat in the exhaust as well - which doesn't do the noise reading any harm either!
Ben
MK9R
posted on 18/5/03 at 09:52 PM Reply With Quote
Arse! More expense!
Cheers Austen
RGB car number 9
www.trackace.co.uk
