Author: Subject: ZX9R Dial faces
MK9R
posted on 19/5/03 at 10:24 AM Reply With Quote
ZX9R Dial faces
I have spoken with a supplier and can get a set of matching dial faces that will replace the ZX9R dial faces and will match a set of 52mm gauges (oil temp, water temp. oil pressure, fuel). Basically it will cost £100 (+/- a few pounds) +VAT for the entire run, so if i can get 4 more people interested it will only cost us £20-£30 each. We can have a Kawasaki or ZX9R logo added aswell if required.
Anyone interested?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
ned
posted on 19/5/03 at 11:53 AM Reply With Quote
would be if i had a bike engine..
oops! did i say that out loud.
beware, I've got yellow skin
Macca
posted on 19/5/03 at 12:08 PM Reply With Quote
Would it be possible to rescale the speedo to a more usable figure at the same time, say 130ish mph max?
Could use a yellow box to suit the change and allow full use of the movement.
Either way will be intersted if you could give a little more detail.
Cheers Col
MK9R
posted on 19/5/03 at 01:13 PM Reply With Quote
Yes its possible, but the only problem would be that the trip meter/mileage would be wrong
To compensate for the wrong speed reading we have used 3 instead of 4 pick ups for the speedo, apparently the speedo is only about 8% out this way.
What would you rather, incorrect mileage with better speedo range, or correct mileage with not so good scale? Not sure myself. If we can 6 of us interested i am happy to go with the vote
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 20/5/03 at 08:44 AM Reply With Quote
no one else? Thats the end of that then
Cheers Austen
RGB car number 9
www.trackace.co.uk
