Author: Subject: Negative pressure
mdc124
posted on 19/5/03 at 06:33 PM Reply With Quote
Negative pressure
Can anyone tell me what suction a blade carb gives when being balanced?
Strange Question? I want to consider using it for servo braking
Matthew
Http://www.farend.co.uk/
The first MK Turnkey Indy
mdc124
posted on 22/5/03 at 08:23 PM Reply With Quote
Wow! Have I stumped you all?
Has no - one ever balanced thier carbs?
paulf
posted on 22/5/03 at 09:28 PM Reply With Quote
There is little suction when balancing carbs as it is done at tick over. Maybe you could use the balance points for a vacuum source but i think you would need to use more than one point which may affect the carb balance.
Paul.
