Author: Subject: Could you use an LCD Power Commander Screen for the clocks?
Omni
posted on 6/8/07 at 12:35 PM Reply With Quote
Hi Guys,
I found this on the Power Commander Website
Do you think they would pass the SVA?
O
matt_claydon
posted on 6/8/07 at 01:04 PM Reply With Quote
There is a production car which has this (can't remember what it is though), so it should be OK. That said, SVA rules can differ so maybe a call to VOSA helpline would be a good idea. 01792 458 888
mike smith1
posted on 6/8/07 at 01:29 PM Reply With Quote
I wouldn't have thought it would have been a problem as long as it meets the interior projection rules.
Best to check with them as Matt says though
Mike
designer
posted on 6/8/07 at 03:15 PM Reply With Quote
A lot of American experimental planes use these as the dash.
Davey D
posted on 6/8/07 at 03:58 PM Reply With Quote
only problem with LCD screens can be the glare from sunlight making them very difficult/impossible to read
jimgiblett
posted on 6/8/07 at 04:40 PM Reply With Quote
You would need an odometer, hazard and brake warnings as well.
As said previously LED screens are cr8p in bright sunshine unless you can get a good cowl over/around them.
- Jim
