Author: Subject: ZX9R CARB BALANCE
larrythelathe
posted on 29/4/08 at 07:09 PM Reply With Quote
ZX9R CARB BALANCE
Really hoping some can help i have download a workshop manual but don't under stand how to balance my carbs ( position of the vacuum pickups and the adjuster)
thanks in advance for any advice.
Eggy
posted on 29/4/08 at 07:17 PM Reply With Quote
I've got an idiots guide if that helps but it's in "word" format so I can email (or if someone tells me how to) I can post it
try this......
http://www.bikersoracle.com/zx9/forum/showthread.php?t=2375
[Edited on 29/4/08 by Eggy]
larrythelathe
posted on 29/4/08 at 07:20 PM Reply With Quote
idiot
i am that idiot larrythelathe@msn.com
thanks
Wadders
posted on 29/4/08 at 07:39 PM Reply With Quote
Just borrowed the wifes best slippers and had a peek in the garage
vacuum pipes are under each inlet manifold (little metal pipes with a rubber blanking cap on)
adjustment looks like the screws directly in between the inlets, looking down from the top, mine have a blob of yellow paint on the heads.
If your still struggling i'll try and dig out the haynes for you.
AL.
]Originally posted by larrythelathe
mistergrumpy
posted on 29/4/08 at 07:48 PM Reply With Quote
Borrowed from MK9R's archive but I think these are the points you need? Someone correct me if not
Carbs Underside
Carbs Underside
[Edited on 29/4/08 by mistergrumpy]
Forget that I think thse are the drain points I'm digging for a better picture of some carbs.
larrythelathe
posted on 29/4/08 at 07:52 PM Reply With Quote
ok
i used my own shoes
i have a pipe that goes between inlet 1 and 4 and then blanked
i seem to have 3 adjusters is this right.
do i only need to measure the inlet on 1 and 4?
mistergrumpy
posted on 29/4/08 at 07:58 PM Reply With Quote
Have a look at this mate from another forum
here
larrythelathe
posted on 29/4/08 at 08:00 PM Reply With Quote
aaarrrr
at last th penny drops
thanks all
mistergrumpy
posted on 29/4/08 at 08:02 PM Reply With Quote
Have a look at the rest of the job here
Eggy
posted on 29/4/08 at 08:07 PM Reply With Quote
As above!
larrythelathe
posted on 29/4/08 at 08:13 PM Reply With Quote
yup
i just wasn't getting it
anyone happen to know were to get some
vacuum take offs? for the blanked ports?
Eggy
posted on 29/4/08 at 08:25 PM Reply With Quote
Mr Kawasaki - or his local friendly stealers!!
