Author: Subject: Sierra Estate
eenud
posted on 18/10/02 at 06:34 PM Reply With Quote
Sierra Estate
I have been offered a cheap H reg Sierra Estate, which has just failed its test. Is the rear end the same as the saloon. Any other comment would be welcome before i go and look.
Ian
bsilly
posted on 18/10/02 at 06:44 PM Reply With Quote
rear end is same but for shock mounts in different place,more shape to trailing arm,and bigger brakes.
mainly digger drivin me
Dunc
posted on 19/10/02 at 11:12 PM Reply With Quote
Whats the engine?
eenud
posted on 27/10/02 at 08:44 AM Reply With Quote
a State
Dunc,
The engine is a CVH 1800, but I would rather fit a cross flow. I do want to use the rest of the running gear.
Ian
Highcost builder
posted on 27/10/02 at 08:00 PM Reply With Quote
good man x flow.
loggyboy
posted on 30/8/17 at 09:36 AM Reply With Quote
Originally posted by eenud
Dunc,
Ian
Good one to break as the sump is worth more than rest of engine on the CVH as they can be modded to suit the Zetec.
Starter can also be used on a zetec conversion (if its the slimine one). So you can make some money back from those.
Mistral Motorsport
mcerd1
posted on 30/8/17 at 12:03 PM Reply With Quote
Sounds like a decent donor car to me
H reg with a 1.8 CVH - should have a 5 speed type 9 box with a short input shaft (pretty good for an X-flow, Pinto or Zetec E)
as above the CVH sump (and some other odds and sods) should be useful to someone fitting a Zetec E, so don't just bin it
the diff could be either a 7" or 7.5" at that age (both likely to be a 3.9 ratio)
the axle code on the VIN plate will tell you what it had originally, but best to check the diff itself
the driveshafts could be push-in type if its got rear drums (which I believe is most common on this version), but it might have the bolt-on version if its got rear disc brakes instead (ie. if it had the optional ABS)
the front brakes will be either 240mm or 260mm vented ones, but the hubs are the same for both anyway
Benzine
posted on 30/8/17 at 12:33 PM Reply With Quote
That's quite a thread bump right there
loggyboy
posted on 30/8/17 at 12:38 PM Reply With Quote
Christ - someone else must have bumped and then deleted their post!
[Edited on 30-8-17 by loggyboy]
Mistral Motorsport
mcerd1
posted on 30/8/17 at 03:06 PM Reply With Quote
i didn't spot that either... I'm blaming sleep deprivation (up all night with a teething baby again )
